Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
Post by Coopervid » Mon Feb 09, 2026 4:45 pm
hewhois wrote:
Mon Feb 09, 2026 4:04 pm
Coopervid wrote:
Mon Feb 09, 2026 10:43 am
hewhois wrote:
Sun Feb 08, 2026 8:38 pm
I have the below drive, please help for UHD support.
PM sent.
Just a newbie question, the drive still remains Mdisc capable, right?
Yes, of course.
bifboy28
Post by bifboy28 » Mon Feb 09, 2026 9:40 pm
Hey, I would like the firmware too please.
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.03
Serial number:
Firmware date: 2015-05-14
Highest AACS version: 66
Drive platform: RS8510
Firmware version: 1.03/ID19
Post by Billycar11 » Tue Feb 10, 2026 1:27 am
Revision: 1.03
Serial number:
Sure just email me that drive info section see below for email
privacy_user_mkv
Post by privacy_user_mkv » Wed Feb 11, 2026 4:48 am
Hello there! I have the following very similar drives. I would like to get UHD support working. I have 3 drives that are identical except for the serial numbers.
Revision: 1.14
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Can somebody help me cross flash them?
iluvripping
Post by iluvripping » Wed Feb 11, 2026 11:36 am
Hi Coopervid, I just got this drive from Japan on ebay yesterday. It's dated October 2016? Could I get the flasher?
Revision: 1.03
Serial number: QKDL754551WL
Post by Coopervid » Wed Feb 11, 2026 12:44 pm
Revision: 1.14
PM sent.
Post by Coopervid » Wed Feb 11, 2026 12:45 pm
Revision: 1.03
PM sent.
kitty
Post by kitty » Wed Feb 11, 2026 5:02 pm
Hi together,
I recently bought a Verbatim 43890 with the model code BIAA including the Pioneer BDR-UD03.
But when I look at the drive information in MakeMKV, I see no LibreDrive information listed.
OS device name: /dev/sr0
Revision: 1.14
Serial number: xxx
Highest AACS version: 81
Also if I run makemkvcon on the drive I do not get more information:
Loaded SDF.bin version 0xa5
Pioneer firmware module v1.20
Commands:
  dump [auto|full] dumps firmware image
    dump full      - dumps full rom image (if not disabled in firmware)
    dump auto      - dumps full image if possible, info data otherwise
    speed get      - prints current speed mode setting
    speed set MODE - writes new default speed mode to EEPROM
Command produced 0 file(s)
Does that mean the drive is broken, or can it still be flashed?
Post by Coopervid » Wed Feb 11, 2026 5:49 pm
Hi together,
Revision: 1.14
Serial number: xxx
Commands:
Please install Windows in a VM - best is VMWare - and post then the Makemkv info from Windows. You need to do this anyway if the drive is flashable. Or connect it to a Windows computer and report back then.
hewhois
Post by hewhois » Wed Feb 11, 2026 5:58 pm
Hey Coopervid,
Not sure if I am doing something incorrect. After the process, instead of listing as BD-03, the drive shows up as BD-04.
But when I insert a Blu-ray+4K disc, the contents still show as only Blu ray in makemkv. Just like it was doing prior to any changes.
It also does not change the firmware date and version. Am I doing something wrong?
Current drive info.
OS device name: E:
Current profile: BD-R SRM
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number:
Highest AACS version: 50
Drive platform: RS8A10
Post by Coopervid » Wed Feb 11, 2026 7:22 pm
Hey Coopervid,
Current drive info.
OS device name: E:
Revision: 1.14
Serial number:
Put an UHD in it.
kitty
Post by kitty » Wed Feb 11, 2026 8:27 pm
Hi together,
Revision: 1.14
Serial number: xxx
Commands:
Thanks a lot for your help.
Indeed you are absolutely right, on a VM with Windows the LibreDrive information is showing up (the drive information is a bit miss-mapped from the VM I guess).
(Kind of new to me, all my LG drives show the LibreDrive information before and after flashing on Linux^^)
Here is the output:
OS device name: E:
Manufacturer: VBOX
Product: CD-ROM
Revision: 1.0
Serial number: BADLxxx
Post by Coopervid » Wed Feb 11, 2026 9:04 pm
Fine. PM sent to flash it to UD04 for reading UHD discs.
kitty
Post by kitty » Thu Feb 12, 2026 12:23 am
Awesome, it worked thanks :)
yu-yevon
Post by yu-yevon » Thu Feb 12, 2026 3:13 am
Why is everyone paying for this firmware flasher? PM me and I can give it to you for free.
