Unable to rip DVDs from a specific distributor
Otto27
Re: Unable to rip DVDs from a specific distributor
Post by Otto27 » Thu Aug 14, 2025 7:05 am
I am also having the same problem with Entertainment One (EOne) DVDs.
Using version 1.18.1 of MakeMKV and a windows 11 laptop. (tried previous versions of MakeMKV as mentioned but they do not work either).
MKV Detects the DVD but fails to open - The DVD can be played with VLC:
MakeMKV v1.18.1 win(x64-release) started
Calculated BUP offset for VTS #0 does not match one in IFO header.
IFO file for VTS #0 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Disc Information
Label: MOST_WANTED_MAN
Timestamp: 2014-12-01 13:11:23
Protection: CSS/CPPM
Data capacity: 7.26 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
Thank you
Otto27
Post by Otto27 » Sat Jan 31, 2026 5:00 pm
Is there any update on this please - still cannot copy e-one disks
bunk3m
Post by bunk3m » Sun Feb 08, 2026 2:31 pm
pneumatic wrote: Tue Apr 23, 2024 2:08 pm I am able to rip the disc in MakeMKV using older version 1.16.7 (hosted at videohelp.com).
As there are other reports of this happening with other discs I'll make a new thread for that topic.
This worked for me also.
I had a similar issue with the 1.18 series, The DVDs that I was looking at were looking to take over an hour to scan. It is unusual as I had ripped them before and don't remember it taking so long. So I downloaded 1.16.7 and it is now back to ~5-10 min to scan.
Post by dcoke22 » Sun Feb 22, 2026 5:07 pm
For future reference older versions of MakeMKV can be downloaded at https://makemkv.com/download/old/
FortWire26
Post by FortWire26 » Sat Apr 04, 2026 4:34 am
I wonder what caused the regression that makes the newer version incompatible. It would be nice to have a toggle to be able to ignore structure errors that this copy protect creates / revert to the legacy behaviour in the latest version so its at least possible to copy these discs.
1bellb
Post by 1bellb » Fri Jul 31, 2026 5:39 pm
I'm having this exact same issue. I can't get the DVD Decrypter to work, I just get loads of errors.
And I tried installing MakeMKV 1.16.7, but when I open it, I just get a warning saying the software is too old and I need to install the latest version.
Is there any other solutions to this issue?
