Drive was manufactured 2014
Krondorf
Actually... i'm pretty sure it can't...
rubenegmond
Hello I tried flashing my ASUS BW-16D1H-U E116 today but to no avail, I managed to get the Updating Failure #1 is the bin file provided in the firmware pack old? Could anyone help me please.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: CCDL090057WL
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E116/ID71
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
rubenegmond wrote: Mon Dec 29, 2025 7:22 pm Hello I tried flashing my ASUS BW-16D1H-U E116 today but to no avail, I managed to get the Updating Failure #1 is the bin file provided in the firmware pack old? Could anyone help me please.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
This is a Pioneer drive. You cannot flash this with the public tools. Contact Billycar11 and he should be able to help you.
Krondorf
Howdy, having to upgrade the drive in my HP SFF PC and i'm thinking of getting this:
https://www.amazon.com.au/dp/B09XTBXM67
Thoughts? Would this be flashable etc?
bu50n is just a HP rebrand of BU40N so should be flashableKrondorf wrote: Sun Feb 01, 2026 5:16 am Howdy, having to upgrade the drive in my HP SFF PC and i'm thinking of getting this:
yackov_bd
Hello all!, I just got an Asus Drive, BW-16D1H-U, and without any flashing it let me rip 4k blurays, the question that I have is... Should I flash it anyway or not?. The info on the drive is the following:
I appreciate your opinions and advice, thank you!
Información de unidad de disco
Nombre del SO del dispositivo: /dev/sr0
Fabricante: ASUS
Producto: BW-16D1H-U
Revisión: A201
Número de serie: SIK9TH77E364
Fecha del firmware: 2116-01-14 13:58
Marcas de cifrado bus: 1F
Highest AACS version: 77
Firmware version: 0.A201W
No hay disco insertado
yes that can beflashed to do UHD see guide below or email me or marty for an auto flasheryackov_bd wrote: Sun Feb 08, 2026 9:48 am Hello all!, I just got an Asus Drive, BW-16D1H-U, and without any flashing it let me rip 4k blurays, the question that I have is... Should I flash it anyway or not?. The info on the drive is the following:I appreciate your opinions and advice, thank you!Code: Select all
################################### Información de unidad de disco Nombre del SO del dispositivo: /dev/sr0 Fabricante: ASUS Producto: BW-16D1H-U Revisión: A201 Número de serie: SIK9TH77E364 Fecha del firmware: 2116-01-14 13:58 Marcas de cifrado bus: 1F Highest AACS version: 77 LibreDrive Information Status: Enabled Drive platform: MT1959 Firmware type: Original (unpatched) Firmware version: 0.A201W DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No hay disco insertado #####################################
Krondorf
Just got the drive, and installed it...Billycar11 wrote: Sun Feb 01, 2026 5:36 ambu50n is just a HP rebrand of BU40N so should be flashableKrondorf wrote: Sun Feb 01, 2026 5:16 am Howdy, having to upgrade the drive in my HP SFF PC and i'm thinking of getting this:
I can't read bluray discs at all... unless i start makemkv first... is that normal? Haven't tried any other software yet...
I would have though it would let me read a disc at least?
Edit: my external buffalo drive from earlier seems to be able to read discs without makemkv running...
New drive info:
OS device name: F:
Current profile: DVD-ROM
Product: BD-RE BU50N
Revision: CC01
Serial number: 708HS009586
Firmware date: 2117-06-28 09:34
Bus encryption flags: 1F
Highest AACS version: 28
Firmware version: 0.CC01V
not normal you should see the disc in the os before ever opening makemkvKrondorf wrote: Wed Feb 11, 2026 5:05 am Just got the drive, and installed it...
Krondorf
That's what i thought too...
but i can reproduce it...
load makemkv i can read disc...
close makemkv and insert disc.. nothing...
Edit:
Actually.. weird thing.... i left it sitting while sending message to seller... and after about 5 minutes the disc info popped up in explorer... weird...
will have to investigate
Edit:
