Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
pradogx wrote: Fri Jan 30, 2026 3:22 am Coopervid,
Can you help me out with this as well? Much appreciated!
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: xxxxxxxxxxxx
Firmware date: 2020-06-15
Highest AACS version: 68
Drive platform: RS8511
Firmware version: 1.14
PM sent.
Idaho121
Post by Idaho121 »
Another request!
OS device name: E:
Revision: 1.14
Serial number: XXXXXXXXXX
Highest AACS version: 77
Idaho121 wrote: Sat Feb 07, 2026 9:16 pm Another request!
OS device name: E:
Revision: 1.14
Email me that drive info section see below for email
rob_levine
Post by rob_levine »
Hi - another request. In this case, I've already flashed to 1.03 but have two 4k UHD Blu-Rays, neither of which work. Normal Blu-Rays working fine.
OS device name: G:
Product: BD-RE BU40N
Revision: 1.03
Serial number:
Highest AACS version: 82
Firmware version: 1.03
rob_levine wrote: Fri Apr 24, 2026 9:17 am Hi - another request. In this case, I've already flashed to 1.03 but have two 4k UHD Blu-Rays, neither of which work. Normal Blu-Rays working fine.
OS device name: G:
Revision: 1.03
Serial number:
You need to provide some info about why they are not working for UHD. Perhaps copy and paste the log window text when attempting a UHD rip?
rob_levine
Thanks for the quick reply. Sure - info and logs attached for both the failing discs.
DISK 2 - ANDOR.txt
(66.58 KiB) Downloaded 1297 times
DISK 1 - INCEPTION.txt
(66.61 KiB) Downloaded 1350 times
rob_levine wrote: Sat Apr 25, 2026 9:51 am Thanks for the quick reply. Sure - info and logs attached for both the failing discs.
Have you tried power cycling your drive?
coconut26
Post by coconut26 »
I have problems with a 43890 Verbatim USB Slim Writer (ans I'm new to subjects UHD with makemkv):
Laufwerksinformation
OS-Gerätename: /dev/sr2
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer:XXXXXXXXXXXXXXx
Firmware-Datum: 2020-06-15
It run's fine without UHD.I need to unlock, if possible.
It's not able to fully dump the firmware (and has no rawflash option):
makemkvcon f -d /dev/sr2 help
Pioneer firmware module v1.20
Commands:
dump [auto|full] dumps firmware image
dump full - dumps full rom image (if not disabled in firmware)
dump auto - dumps full image if possible, info data otherwise
speed get - prints current speed mode setting
speed set MODE - writes new default speed mode to EEPROM
What can be done in this case, can you please comment this.
Kind regards
coconut26 wrote: Sun Jun 07, 2026 10:01 am Hi,
Produzent: PIONEER
Revision: 1.14
Commands:
Kind regards
Yes it can do UHD but not with the flashing tool you are asking about
sure email me that info and all others email me
no need to post your info here publicly just reach out to me directly
see below for email
