Pioneer BDR-UD03 FW1.03 Crossflash?
elver
#1 Post by elver » Sat Feb 07, 2026 2:49 pm
I have a Pioneer BDR-UD03, manufacture date on the sticker is 2017, it's in a Vantec enclosure. This is the info from MakeMKV:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.03
Firmware date: 2015-05-14
Drive platform: RS8510
Firmware version: 1.03/ID19
I've read online that the drive would need to be crossflashed with BDR-UD04 firmware, but it looks to me like MakeMKV is happy to use it as-is for ripping UHD discs, is this correct? or will I see better compatibility crossflashing?
Many thanks,
elver
Re: Pioneer BDR-UD03 FW1.03 Crossflash?
#2 Post by Billycar11 » Sat Feb 07, 2026 4:25 pm
elver wrote: Sat Feb 07, 2026 2:49 pm Hi,
Revision: 1.03
Many thanks,
elver
Yes can be made to do UHD email me that drive info section see below for email
Thanks,
Billy
#3 Post by MartyMcNuts » Sat Feb 07, 2026 10:09 pm
Revision: 1.03
Many thanks,
elver
No, it can't read UHD discs until cross-flashed to the BDR-UD04 (UHD model) firmware.
elver
#4 Post by elver » Sat Feb 07, 2026 11:12 pm
Thanks both,
I've sent an email over to Billy 👍
ProGT
#5 Post by ProGT » Tue Sep 01, 2026 2:01 pm
Hi there,
I was wondering if there are still any BDR-UD04 firmware dumps anyone would be willing to share as I was thinking of buying a new old stock BDR-UD03 to rip UHD discs. I was also thinking about the LG BU40N, but lost interest after reading about the jamless playback. I have tried to find a reliable source online which may have a firmware dump, but I haven’t had any luck yet. Thanks in advance.
Kind regards.
#6 Post by Billycar11 » Tue Sep 01, 2026 2:37 pm
ProGT wrote: Tue Sep 01, 2026 2:01 pm Hi there,
Kind regards.
You just have to email me for the flash kit see below for email
Drive info is required to send the correct kit
Copy and paste it from makemkv
Mucki75
#7 Post by Mucki75 » Thu Sep 10, 2026 4:11 pm
Hi Billycar11,
I have the same problem with the same drive:
Laufwerksinformation
OS-Gerätename: G:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.03
Serienummer: PJDL290364WL
Firmware-Datum: 2015-05-14
Markierungen der Bus-VerschlĂĽsselung: 1B
Highest AACS version: 71
Can you please help me also? :-)
#8 Post by Coopervid » Thu Sep 10, 2026 8:14 pm
Mucki75 wrote: Thu Sep 10, 2026 4:11 pm Hi Coopervid,
OS-Gerätename: G:
Produzent: PIONEER
Revision: 1.03
PM is coming.The forum is terribly slow.
#9 Post by Billycar11 » Thu Sep 10, 2026 8:24 pm
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
