Pioneer BDR-209DBK Crossflash
HA-Freak
Post by HA-Freak » Mon Apr 14, 2025 4:18 pm
Hello everyone,
is there a way to crossflash this drive to BDR-211 to read UHDs ?
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.20
Serial number: ...
Firmware date: 2014-04-08
Bus encryption flags: 13
Highest AACS version: 77
Drive platform: RS8600
Firmware version: 1.20/ID61
Best Regards HA-Freak
ulcjyc
Re: Pioneer BDR-209DBK Crossflash
Post by ulcjyc » Mon Aug 11, 2025 8:24 am
Hi HA-Freak, ich have the exact same question like you. You hav found already a solution to crossflash the BDR-209DBK?
Thanks and greets, Jon
Post by Billycar11 » Mon Aug 11, 2025 8:29 am
ulcjyc wrote: Mon Aug 11, 2025 8:24 am Hi HA-Freak, ich have the exact same question like you. You hav found already a solution to crossflash the BDR-209DBK?
HA-Freak wrote: Mon Apr 14, 2025 4:18 pm Hello everyone,
Revision: 1.20
Serial number: ...
yes email me your makemkv drive info like this i have a flasher for it
see below for email.
petert
Post by petert » Mon Sep 15, 2025 2:12 pm
i have a BDR-209DBK to, what have i to do.
witch flasher do you mean ? Drvinfo oder DBRflasher ?
Post by Billycar11 » Mon Sep 15, 2025 2:13 pm
petert wrote: Mon Sep 15, 2025 2:12 pm Hello,
Just email me the info like others posted above
See email below
nickname777
Post by nickname777 » Fri Feb 06, 2026 3:09 pm
Hi Forum, I don't have a BDR-209DBK available yet, but plan on buying one.
So I cannot post the makemkv-info and the seller won't provide this.
So my question:
Is there something to consider when buy a BDR-209DBK?
It seems to be manufactured in early 2015 - can ALL variants of this drive get flashed to accept/rip UHDs?
Thanks a lot,
nickname777
Post by Coopervid » Fri Feb 06, 2026 4:34 pm
nickname777 wrote: Fri Feb 06, 2026 3:09 pm Hi Forum, I don't have a BDR-209DBK available yet, but plan on buying one.
So my question:
Thanks a lot,
nickname777
Most likely a no-brainer. Be careful if the seller is in China. A lot of fakes are sold from there.
nickname777
Post by nickname777 » Fri Feb 06, 2026 6:28 pm
Coopervid wrote: Fri Feb 06, 2026 4:34 pm Most likely a no-brainer. Be careful if the seller is in China. A lot of fakes are sold from there.
Great thanks - it is not from china, so I try get my hands on it and then I probably should contact @Billycar11, right?
Can I expect better results from this drive, than from a Verbatim 43888/BU40N (only one in two discs rips without errors)?
Post by Coopervid » Fri Feb 06, 2026 7:32 pm
nickname777 wrote: Fri Feb 06, 2026 6:28 pm
You can contact Billy or myself for flashing. Pioneers are the best rippers but limited to 4x speed for UHD.
nickname777
Post by nickname777 » Fri Feb 06, 2026 8:38 pm
Coopervid wrote: Fri Feb 06, 2026 7:32 pm You can contact Billy or myself for flashing. Pioneers are the best rippers but limited to 4x speed for UHD.
Great - better slow, than no usable result :lol:
I come back to you, when I have the drive and the information available.
