Hi there, I recently acquired an internal BD drive like I've been wanting for ages, this Asus one was the only one I could really find, so that's what I got.
I want to flash it, but just want to check I'm doing everything right before I brick it or something.
It's info is:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: (idk if this is needed or if it's something I should censor)
Firmware date: 2120-12-01 17:59
Bus encryption flags: 1F
Highest AACS version: 82
Yes, that is the Firmware date, it's from the future apparently. I assume it's meant to say 2021-12-01, idk how that happened.
The manufacture date on the top of the drive says August 2025, so it's pretty new.
I have downloaded SDFtool flasher as well as the firmware pack.
I've already used it to read the firmware and create a current firmware dump as backup, but here's where I'm not sure where to go next.
According to the SDF thread, revision 3.11 is encrypted and it says "If your desktop drive has encrypted firmware, flash WH16NS60 1.02-MK first, then you can either leave it as is or flash any other desktop drive firmware if you want to."
But the UHD flashing guide say "Asus BW-16D1HT on any Firmware directly to > Asus BW-16D1HT 3.10MK"
So I'm not really sure which one to do here.
Also will either of these fix the sleep bug thing, or will I still need to flash it to WH16NS60 or whatever?
Also idk if it's relevant, but I'd like to keep the M Disc compatability if possible.
And is it worth installing any of the software that it came with on disc, like power2go or e-green?
Flashing Asus BW-16D1HT
Re: Flashing Asus BW-16D1HT
keeping burning is by using asus fw
sleep bug is fixed by wh16ns60 fw
sometimes burning still works with lg fw on asus drives but not always that why we recommend asus fw on asus drives
Oh okay, so flashing it to the Asus 3.10 firmware is alright then? I don't need to first flash the WH16 firmware like the SDF thread says?
I can put up with the sleep bug I guess, I'll just not leave a UHD disc in there for 2 mintutes.
