Verbatim 43889
doannie
Verbatim 43889
#1 Post by doannie » Thu Feb 05, 2026 12:08 am
Is Verbatim 43889 drive any good? Will I have able to rip UHD and use it as a LibreDrive?
Re: Verbatim 43889
#2 Post by Woodstock » Thu Feb 05, 2026 3:08 pm
Searching for "Verbatim 43889" finds over 60 matches, including what to flash various versions of it with.
yu-yevon
Re: Verbatim 43889
#3 Post by yu-yevon » Thu Feb 05, 2026 7:10 pm
doannie wrote: Thu Feb 05, 2026 12:08 am Is Verbatim 43889 drive any good? Will I have able to rip UHD and use it as a LibreDrive?
If it has a Pioneer ud03 drive, contact me and I get you the firmware flasher to make it uhd for free.
zittrig
Re: Verbatim 43889
#4 Post by zittrig » Fri Feb 06, 2026 10:23 am
The 43889 has the Pioneer BDR-UD03 inside (older models) or the LG BU40N (newer models).
Both need to flash for ripping 4K disks with MakeMKV.
For pioneer you need the flasher from Billy oder Marty for example. The LG you can flash yourself with the flashing guide which you can find here.
CAKO0503
Re: Verbatim 43889
#5 Post by CAKO0503 » Mon Mar 09, 2026 8:54 am
Would be great if you could share it with me. I'm new here and seems like I can't write pm?
Re: Verbatim 43889
#6 Post by Billycar11 » Tue Mar 10, 2026 1:09 pm
CAKO0503 wrote: Mon Mar 09, 2026 8:54 am Would be great if you could share it with me. I'm new here and seems like I can't write pm?
Sure email me that drive info section see below for email
For all others there is no need to post your makemkv drive info section publicly just email it to me directly
