Masterpiece Les Miserables help
C0C0B
Post by C0C0B »
So I bought the PBS Masterpiece of Les Miserables and I wanted to rip the episodes for Plex however it's a complete mess and I don't have to room to rip every single file. I was wondering if anyone had this or had an idea of how to figure out which files to take. There are two discs and both look like this. There are 3 episodes on both discs and I originally thought I could differentiate based on file size but they're all either 11.5 GB or 12.8 GB. There are two smaller files however they're only 2 and 3 chapters respectively. So long story short I was hoping someone would have some insight on what to do.
2019-06-11 (1).png (239.89 KiB) Viewed 19414 times
Disc Folder
Disc Folder
MovieCollector
Re: Masterpiece Les Miserables help
Post by MovieCollector »
This is what I use. I have not watched each episode to verify.
Episode 1: 00731.mpls
Episode 2: 00578.mpls
Episode 3: 00332.mpls
Episode 4: 00576.mpls
Episode 5: 00817.mpls
Episode 6: 00545.mpls
thetoad
Post by thetoad »
MovieCollector wrote: Sat Jun 22, 2019 7:09 pm This is what I use. I have not watched each episode to verify.
anydvd concurs
[disc]
type=BD-R
version=AnyDVD HD 8.3.6.0 (BDPHash.bin 19-05-23)
totalsectors=20356480
label=LES MISERABLES DISC 1
speedmenu=0
region=1
playlists=731, 578, 332
3D=0
fps=23
[disc]
type=BD-R
totalsectors=21906688
label=LES MISERABLES DISC 2
speedmenu=0
region=1
playlists=576, 817, 545
3D=0
fps=23
mwoliver
Post by mwoliver »
Using MakeMKV 1.18.3 on Manjaro and pointing MakeMKV to a jdk-21.0.10 installation, I can confirm the above. I am attaching screenshots showing the title discovery in MakeMKV and also the information for each title is noted below. I'll also say that this disc set I have is unfriendly to my Panasonic DP-UB9000, specifically that disc 1 will only play Part 2 no matter which part I select from the menu. From that BD player there is no way to access Part 1 or Part 3 on disc 1, which is quite ridiculous. I returned the original set for a replacement from Amazon and the replacement exhibited the same behavior. There is also at least one other review on Amazon that notes the same problem. For a non-profit outfit like PBS to go to Lionsgate-length shenanigans to obfuscate the titles and make life hard on paying customers is beyond ridiculous.
Since I was able to successfully archive the episodes I kept the paid-for replacement discs, even though I can't watch them on my DP-UB9000. I wouldn't feel right shipping them back for a refund while having successfully made the MKVs, but still the time and annoyance to sort this out may have justified it...
Title information
Name: Les Misérables Disc 1 (English)
Comment: T1
Source file name: 00731.mpls
Duration: 1:02:16
Chapters count: 6
Segment count: 1
Segment map: 8
File name: Les Misérables Disc 1-T1_t00.mkv
Title information
Comment: T2
Source file name: 00578.mpls
Duration: 1:02:16
Chapters count: 6
Segment count: 14
Segment map: 510,502,500,505,509,503,512,513,507,506,508,504,511,501
File name: Les Misérables Disc 1-T2_t01.mkv
Title information
Comment: T3
Source file name: 00332.mpls
Duration: 1:01:35
Chapters count: 6
Segment count: 1
Segment map: 13
File name: Les Misérables Disc 1-T3_t02.mkv
Title information
Name: Les Misérables Disc 2 (English)
Comment: T1
Source file name: 00576.mpls
Duration: 1:02:16
Chapters count: 6
Segment count: 1
Segment map: 8
File name: Les Misérables Disc 2-T1_t02.mkv
Title information
Comment: T2
Source file name: 00817.mpls
Duration: 1:02:11
Chapters count: 6
Segment count: 1
Segment map: 12
File name: Les Misérables Disc 2-T2_t00.mkv
Title information
Comment: T3
Source file name: 00545.mpls
Duration: 1:16:45
Chapters count: 7
Segment count: 11
Segment map: 506,509,507,505,508,503,510,502,504,500,501
File name: Les Misérables Disc 2-T3_t03.mkv
Title information
Comment: T13
Source file name: 00014.mpls
Duration: 0:14:46
Chapters count: 4
Segment count: 4
Segment map: 18,19,20,22
File name: Les Misérables Disc 2-T13_t01.mkv
