Verbatim 43889
doannie
Verbatim 43889
Post by doannie »
Is Verbatim 43889 drive any good? Will I have able to rip UHD and use it as a LibreDrive?
Re: Verbatim 43889
Searching for "Verbatim 43889" finds over 60 matches, including what to flash various versions of it with.
yu-yevon
Re: Verbatim 43889
Post by yu-yevon »
doannie wrote:
Thu Feb 05, 2026 12:08 am
If it has a Pioneer ud03 drive, contact me and I get you the firmware flasher to make it uhd for free.
zittrig
Re: Verbatim 43889
Post by zittrig »
The 43889 has the Pioneer BDR-UD03 inside (older models) or the LG BU40N (newer models).
Both need to flash for ripping 4K disks with MakeMKV.
For pioneer you need the flasher from Billy oder Marty for example. The LG you can flash yourself with the flashing guide which you can find here.
CAKO0503
Re: Verbatim 43889
Post by CAKO0503 »
Would be great if you could share it with me. I'm new here and seems like I can't write pm?
Re: Verbatim 43889
CAKO0503 wrote:
Mon Mar 09, 2026 8:54 am
Sure email me that drive info section see below for email
For all others there is no need to post your makemkv drive info section publicly just email it to me directly
