LG BU40N not recognized
Eltonmaster
#1 Post by Eltonmaster » Wed Feb 04, 2026 2:04 pm
Hi!
I recently bought an unflashed BU40N with the intent of saving some media.
I also bought an USB-Adapter to connect the drive to my PC. Everything seems to work so far. I can playback files from blu-ray but MakeMKV does not recognize the drive.
The listed information is the following:
Manufacturer: 000000
Product: 9999999999999999
Revision: 1.05
Serial number: MOBP8TE3008
Does somebody know this issue already?
Is the usage via USB-Adapter not supported?
Thanks a lot for your help (and great software ofc),
Eltonmaster
Re: LG BU40N not recognized
#2 Post by Coopervid » Wed Feb 04, 2026 3:29 pm
Eltonmaster wrote: Wed Feb 04, 2026 2:04 pm Hi!
Revision: 1.05
Eltonmaster
Most USB adapters only work flawlessy with SATA HDDs and SSDs, not with optical drives. I recommend the BENFEI. Works with Makemkv and allows firmware flashing.
https://www.amazon.com/Benfei-Adapter-C ... r=8-5&th=1
#3 Post by MartyMcNuts » Wed Feb 04, 2026 10:23 pm
Revision: 1.05
Eltonmaster
Yep. the adapter you are using is the issue. Go with Coopervid's recommendation or check the Ultimate UHD Drive Guide 2026 for a list of compatible adapters.
