jjgarcia
Post by jjgarcia »
Any tips or suggestions on how to flash this drive? Thanks again...
jjgarcia wrote: Fri Jan 30, 2026 9:08 pm Hey everyone,
My Pioneer drive sometimes is unable to rip certain blurays.
Is there a firmware flash for the libreDrive?
Is this related to also the ability to read UHD discs or is that something else?
Any help would be much appreciated. Here is my drive info from MakeMKV
Thanks in advance,
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Serial number: PBDL028907UC
Firmware date: 2014-12-26
Highest AACS version: 70
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
comadose
Post by comadose »
mannduro wrote: Sat Jan 31, 2026 12:44 pm
comadose wrote: Fri Jan 30, 2026 3:00 pm I was able to get mine unlocked for free by asking nicely over on the cdrinfo.pl forum. Saved myself $80.
Was this recommendation about my ODD ?
You could certainly ask there. Save yourself some cash.
jjgarcia wrote: Mon Feb 02, 2026 4:43 pm Any tips or suggestions on how to flash this drive? Thanks again...
Thanks in advance,
Revision: 3.01
PM sent.
Your drive with MT1939 chip can't be flashed!
Simplemitch
Post by Simplemitch »
1st time poster here, so sorry if this should be it's own thread but it seemed relevant and hadn't seen discussed here.
Would there be any reason one WOULDN'T want to flash their drive? I just want to make sure there's no hidden gotchas or that I'm not gonna gain functionality in MakeMKV, but lose functionality elsewhere.
My current drive is an LG WH16NS40 on FW 1.05 (so I'd be going to DE_LG_WH16NS40-NS50_1.02)*. I primarily use it to rip BD/DVD via MakeMKV and to rip CDs via iTunes. On increasingly rare occasions I will burn DVDs and CDs.
I also have a mountain of spare 5.25" DVD/CD burners so I could always just add an extra drive if need be.
Thanks.
*side question: Do I need to verify it says NS50 on it before flashing? It'd be a bear to get to it in the PC that it's in...
Simplemitch wrote: Wed Feb 04, 2026 5:44 pm 1st time poster here, so sorry if this should be it's own thread but it seemed relevant and hadn't seen discussed here.
Thanks.
No. Flash to WH16NS60 1.02. No sleep bug and works better with UHDs.
Simplemitch
Coopervid wrote: Wed Feb 04, 2026 7:30 pm
Thanks.
I assume you mean the DE_LG_WH16NS60_1.02_MK file. And that's OK even though I have a 40, not a 60, correct?
Sorry for being paranoid; I like leaving NOTHING to chance.
Simplemitch wrote: Wed Feb 04, 2026 7:51 pm
Thanks.
Not DE. It's in the OLD folder of the firmware pack. It will work.
Simplemitch
Coopervid wrote: Wed Feb 04, 2026 8:42 pm
See! Glad I asked!
But.... there is no "OLD" folder in the All you Need Firmware Pack that I downloaded today and I don't see any links to prior releases. It just has two folders ("Internal Desktop Drives" and "Slim External Drives") each containing nothing but bin files
This is the link I used:
https://www.mediafire.com/file/rak1mk0p ... 9.zip/file
from this page:
viewtopic.php?f=16&t=22896
Have a link to the old one, by chance?
Yes, that is the correct file: DE_LG_WH16NS60_1.02_MK
Also, yes, you must ensure the drive says SVC NS50 on the label, is manufactured after 2015 and has the MT1959 drive platform.
icefloe
Post by icefloe »
Just popping in to say thank you!! My LG WH16NS40 from 2020 arrived today and in just minutes had it flashed. As soon as I saw that it could in fact read UHD disks I registered MakeMKV and it's now ripping a UHD disk. My Ugreen 8 bay NAS is going to get a workout too. lol
mkvuser190
Post by mkvuser190 »
Hi all
I'm new to this forum, and I am very confused by this thread. I don't see my drive or firmware listed, but people in another thread have helped others with the same drive. I have a Pioneer drive, and I am scared to brick it if I do something wrong. Could somebody tell me if my drive is flashable for UHD? Thank you.
OS device name:
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number:
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 63
Drive platform: RS8D30
Firmware version: 1.03
Also, I'm sorry for essentially re-posting this from another thread. I just think this one is more active than the other one.
NobleOccum
Post by NobleOccum »
I'm flashing my drive following the guide in the original post of this thread. Everything seems to go through fine, but MakeMKV doesn't see the drive as any different from how I started, and UHD disks still get ejected.
My drive info from MakeMVK:
Product: BD-RE WH14NS40
Revision: 1.05
Serial number:
Highest AACS version: 82
Harware support: Yes
Firmware support: No
Firmware version: 1.05
And the output from my command:
./makemkvcon f -d '/IOBDServices/AEFAD468' -f /Users/user/Downloads/sdf.bin rawflash main -i /Users/user/Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/WH16NS60/HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin
Reading input file /Users/user/Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/WH16NS60/HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin
Current Drive ID: HL-DT-ST_BD-RE__WH14NS40_1.05_212005061444_KLEO5OD3538
yes
 100% Operation finished
Done successfully
mkvuser190 wrote: Fri Feb 06, 2026 6:12 am Hi all
OS device name:
Revision: 1.03
Serial number:
You need to post your own Makemkv info to be helped.
NobleOccum wrote: Mon Feb 09, 2026 4:47 pm I'm flashing my drive following the guide in the original post of this thread. Everything seems to go through fine, but MakeMKV doesn't see the drive as any different from how I started, and UHD disks still get ejected.
Revision: 1.05
Serial number:
./makemkvcon f -d '/IOBDServices/AEFAD468' -f /Users/*/Downloads/sdf.bin rawflash main -i /Users/*/Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/WH16NS60/HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin
Reading input file /Users/*/Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/WH16NS60/HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin
yes
Done successfully
You need to replace main with enc in your command.
