Internal error - Operation result is incorrect
johnny
#1 Post by johnny » Thu Mar 15, 2012 6:39 pm
after backup of Firefly Discs 1-3 and trying to reopen the copied (and decrypted) content again (MakeMKV 1.7.2, Linux(x64-release)) I get the following messages:
Disc 1
Error 'Internal error - Operation result is incorrect (196)' occurred while reading '/backup/FIREFLYUS_D1/BDMV/CLIPINF/00001.clpi' at offset '2048'
Disc 3
Error 'Posix error - Unknown error 1073741823' occurred while reading '/backup/FIREFLYUS_D3/BDMV/CLIPINF/00011.clpi' at offset '2048'
At least on the first disc one track is missing in the left tree then.
When opening the disc directly, the error does NOT appear and the missing track is selectable.
I made a diff on the mentioned file of the first disc and backup and disc was identical.
Let me know if I can give further information.
setarip_old
Re: Internal error - Operation result is incorrect
#2 Post by setarip_old » Thu Mar 15, 2012 9:19 pm
What software and procedures did you use to decrypt the three original, commercial discs?
johnny
#3 Post by johnny » Thu Mar 15, 2012 9:25 pm
setarip_old wrote:What software and procedures did you use to decrypt the three original, commercial discs?
Yes, of course. Discs are original and in new condition. Only MakeMKV was involved in this process.
Edit: Just made another backup of the disc, resulting in no change. First disc is protected by AACS v9, BD+ v2008.9.
firionicable
#4 Post by firionicable » Tue Mar 20, 2012 4:04 am
What about on Disc 2? Did you get any error message or encountered any problem like slowing down?Image
johnny
#5 Post by johnny » Tue Mar 20, 2012 7:50 am
firionicable wrote:What about on Disc 2? Did you get any error message or encountered any problem like slowing down?Image
Disc 2 has AACS v8, BD+ v2008.9. No error messages appeared. And as far as I can tell no titles are missing. Did not recognize any other suspicious behaviour, too.
Disc 3 is protected by AACS v9, BD+ v2008.9 again by the way. Maybe there is a problem with AACS v9 in combination with BD+ in some way?
#6 Post by mike admin » Sun Mar 25, 2012 8:49 am
Can you please check that all CLPI and MPLS files are identical on disc and in the backup? Do you see anything in MakeMKV log (in file, not in GUI pane). Do you get the same error each time you open a backup?
johnny
#7 Post by johnny » Sun Mar 25, 2012 1:05 pm
mike admin wrote:Can you please check that all CLPI and MPLS files are identical on disc and in the backup? Do you see anything in MakeMKV log (in file, not in GUI pane). Do you get the same error each time you open a backup?
I compared all the files *.clpi and *.mpls on the first disc (normal and backup), then the same on my harddrive, and finally compared them between disc and my harddrive. All are identical.
After I created another backup with activated log debug messages (got no errors here) and opened the directory, I got the same error and some more messages (first disc for now):
003006:0000 Opening files on harddrive at /backup/FIREFLYUS_D1/
001003:0020 DEBUG: Code 34812 at `t+A@JDMZwJznvm%"]:121263038
001003:0020 DEBUG: Code 117637316 at `t+A@JDMZwJznvm%"]:29395678
001003:0020 DEBUG: Code 117637316 at `t+A@JDMZwJznvm%"]:121262049
002003:0000 Error 'Internal error - Operation result is incorrect (196)' occurred while reading '/backup/FIREFLYUS_D1/BDMV/CLIPINF/00001.clpi' at offset '2048'
001003:0020 DEBUG: Code 0 at BP7kxI[0.Y^'= 1z:29398047
DISCID=FF2421BC238549031ADAE397CD2DAEE2F08F1516
003025:0000 Title #00014.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 0 at _2Jce,n:_z/f8#JP_:213132721
001003:0020 DEBUG: Code 0 at _2Jce,n:_z/f8#JP_:121263682
003307:0000 File 00004.mpls was added as title #0
003307:0000 File 00003.mpls was added as title #1
003025:0000 Title #00005.mpls has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00031.mpls has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00002.mpls was added as title #2
003025:0000 Title #00013.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00011.m2ts was added as title #3
003025:0000 Title #00006.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00007.m2ts was added as title #4
003025:0000 Title #00009.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Edit: debuglog from disc 3:
003006:0000 Opening files on harddrive at /backup/FIREFLYUS_D3/
001003:0020 DEBUG: Code 2147483647 at S6v;<\twH~NvS8`_:29393953
001003:0020 DEBUG: Code 2147483647 at `t+A@JDMZwJznvm%"]:29395678
001003:0020 DEBUG: Code 2147483647 at `t+A@JDMZwJznvm%"]:121262049
002003:0000 Error 'Posix error - Unknown error 1073741823' occurred while reading '/backup/FIREFLYUS_D3/BDMV/CLIPINF/00011.clpi' at offset '2048'
DISCID=DDD7302B9A198D46D533AA022919EC5115C22F84
001003:0020 DEBUG: Code 0 at BP7kxI[0.Y^'= 1z:29403314
001003:0020 DEBUG: Code 0 at _2Jce,n:_z/f8#JP_:29397104
001003:0020 DEBUG: Code 0 at _2Jce,n:_z/f8#JP_:213130306
003025:0000 Title #00017.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00027.mpls has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00005.mpls was added as title #1
003025:0000 Title #00021.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00026.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00019.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00003.mpls was added as title #3
003307:0000 File 00006.mpls was added as title #4
003025:0000 Title #00001.mpls has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00027.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00008.m2ts was added as title #5
003025:0000 Title #00009.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00025.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00024.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 75 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00019.m2ts was added as title #6
003307:0000 File 00013.m2ts was added as title #7
003025:0000 Title #00028.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00026.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00023.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00015.m2ts was added as title #8
003025:0000 Title #00020.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00012.m2ts was added as title #9
003025:0000 Title #00018.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Opening disc 2 does not print out any error or DEBUG-messages, so I assume here is all well.
#8 Post by mike admin » Wed Mar 28, 2012 7:18 am
Looks like it's both disc mastering error and a bug in MakeMKV . Please compress with any archiver and send all CLPI and MPLS files from problematic discs to support@makemkv.com . Your backup is apparently correct.
johnny
#9 Post by johnny » Wed Mar 28, 2012 6:35 pm
mike admin wrote:Looks like it's both disc mastering error and a bug in MakeMKV . Please compress with any archiver and send all CLPI and MPLS files from problematic discs to support@makemkv.com . Your backup is apparently correct.
Hi Mike,
I just sent a zip file with all the clpi and mpls files from discs 1 and 3.
Thanks for looking into this!
