Odd behaviour on Unraid
burnedcarpet
Post by burnedcarpet » Wed Feb 04, 2026 7:00 pm
I am using the binhex-makemkv container, it worked better than the other one that there is. I got it set up properly, even got it ripping a disc. Now I get a popup window on a grey background saying "Application failed to initialize NO_ANSWER_FROM_MAKEMKVCON" with an "ok" button which just makes it disapear and then I am just left with a grey screen. I have restarted the system, a few times. Even a full power off and on again. I've not set it up in conjunction with anything, if that's even possible. I'm not terribly advanced at Unraid so, I know i'm begging but please bear that in mind with any responses.
Thank you :)
flojo
Re: Odd behaviour on Unraid
Post by flojo » Wed Feb 04, 2026 9:25 pm
It's a Docker container, so contact the maintainer :-/. Have you fully updated your Linux distro? Maybe look here, but know that you'll have to run commands inside of the container to fix this: viewtopic.php?p=160864#p160864 To get into the Docker container: docker exec -it $the_name_that_you_gave_the_container bash
What was wrong with the containers that used --device=/dev/sr0? The use of --privileged=true never builds confidence.
