Fatal Errors on multiple BDs
jmwhooper
#1 Post by jmwhooper » Wed Nov 25, 2009 9:46 pm
I'm getting errors on blurays when trying to convert from mounted iso, folder BDMV or directly from the iso, both with and without Any DVD enabled, and on 8 out of 12 different movies I've had fatal errors, mostly when Any DVD is enabled, with Any DVD disabled most of the BDs are not recognised by the SVQ file.
This is for Casino -
####### From the log file #######
Debug log started at Wed Nov 25 21:43:06 2009 , written by MakeMKV v1.4.8 beta win(x86-release)
001014:000000:0000 MakeMKV v1.4.8 beta win(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\John/MakeMKV_log.txt
003010:000000:0000 Using direct disc access mode
003310:000000:0000 AACS directory not present, assuming unencrypted disc
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00002
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00005
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00006
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00007
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00010
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00011
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00012
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00013
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00014
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00016
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00017
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00018
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00019
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00020
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00023
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00024
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00025
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00027
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00028
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00029
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00030
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00031
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00032
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00033
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00034
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00035
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00037
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00024.m2ts
003308:000000:0000 Stream #40 of type 'DTS-HD secondary audio' in file 00024.m2ts was skipped
setarip_old
Re: Fatal Errors on multiple BDs
#2 Post by setarip_old » Mon Dec 14, 2009 8:23 am
Hi!
Looks like a bad rip.
Do you have the same problem if you use the actual, original BluRay disc instead of the .ISO image file?
