Two New UHD Sets of LOTR Problems
kingpeep
#1 Post by kingpeep » Wed Feb 04, 2026 3:14 am
I have attached two logs to this post around some issues I am receiving trying to make digital backups of Lord of the Rings (Theatrical and Extended). I have read through the forums that this is a known problematic UHD set. So I expected that I would run into issues, but in my first case, I was only able to rip one of the six discs.
I replaced the set through Amazon and was able to get 3 discs to rip out of the second set. But I am continuously getting errors despite my best efforts at cleaning the discs with dish soap and microfiber cloth :cry: As a side note, I have noticed a foggy haze on some of the discs despite wiping down very clean with microfiber or a sunglasses lense cloth. It takes awhile for that foggy haze to fully disappear.
OS device name: F:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: 012HADB18216
Highest AACS version: 82
Firmware version: 1.02
Disc Information
Label: LOTR_FELLOWSHIP_OF_THE_RING
Timestamp: 2020-10-20 20:30:14
Protection: AACS2.0/C v76
Data capacity: 85.41 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
The log files below show mainly this type of snippet error with AV sync & Hash Check errors at the bottom:
001003:0020 DEBUG: Code 2 at h97u/P'k6LzLo#gYp;Jg:29394758
tp=PJyZDTIoLWeGye9h0s3lOa/VushctmsHYZihx8YW2319Ov4wrPrGfPcrBuPWsBdD93X5EnLKD7ItHfNBWfyWf7Bba8H38n84xcmMBbnNsgNWA7RDYZQke2XPx6pBkuZCTMN/VFJ+/5YP08MRcew1eoVJ3IJQ4Eq25KkMiMLzFxPyPPy9SeWDOnyDmhfNCnY5rorAlGkkCT7WQexIl1h/Wh1/kixI+KNczaspC0AB3gOmTXzMlr9GKzoDiWtwZb07C
004004:0000 The source file '/BDMV/STREAM/00075.m2ts' is corrupt or invalid at offset 32216838144, attempting to work around
tp=Pq/WS1DfyqWH+wrScenJ2UNXqLO9afkJSOWV2GRgsCU1gzeuKoOq6eodlwdYo6p9ROemyUUEamKeZvTrEZWniXfGE5KFm5lQIqScdhnKMMRnToNbm/+YtXAC8KUsjeTHYnArDPlmGccn0YB+b2BkBaHghBygDEYGiVKpp1tUg4t1/BFcVvOlogRfIy0No0/AwMCjVOf4D+H0uVvOS9C4h9YKCx2iYbN3fJfLKD5AjhnfyYsHlEF+ZXC5F7xs=
001003:0020 DEBUG: Code 3 at h97u/P'k6LzLo#gYp;Jg:29394758
tp=PPc/1VKv1ktQ38qlh/sK0nHpydlDV6izvWn5CUjlldhkYLAlNYM3riqDqunqHZcHWKOqfUTnpslFBGpinmb06xGVp4l3xhOShZuZUCKknHYZyjDEZ06DW5v/mLVwAvClLI3kx2JwKwz5ZhnHJ9GAfm9gZAWh4IQcoAxGBolSqadbVIOLdfwRXFbzpaIEXyMtDaNPwMDAo1Tn+A/h9LlbzkvQuIfWCgsdomGzd3yXyyg+QI4Z38mLB5RBfmVwuRe8b
tp=PtW8RE8LLyS3YJCu+C7vGr1471QKhZdYyG90HeqGUlZQ8rtAQLmY5OXb9Ge5Hs6EqN/vxN03lvieOTmxidt/qcrXqw3ZIn3/pkJiUH1aX0IREUpfSjwqWpu02NwI3NwX89F+1pMQ57bMWQGeJeaFhNU+FmFzztZhNAkbu7r0Lw6FHg5s5gd4NdXY+hkUIpV8xWiKcOrVft/58g1//ox8SxbwflZ7BN6UDrin7P+ZrTRSUsQMQTwUbY7CM7tk=
001003:0020 DEBUG: Code 4 at h97u/P'k6LzLo#gYp;Jg:29394758
tp=P1wNA4LVvERPCy8kt2CQrvgu7xq9eO9UCoWXWMhvdB3qhlJWUPK7QEC5mOTl2/RnuR7OhKjf78TdN5b4njk5sYnbf6nK16sN2SJ9/6ZCYlB9Wl9CERFKX0o8KlqbtNjcCNzcF/PRftaTEOe2zFkBniXmhYTVPhZhc87WYTQJG7u69C8OhR4ObOYHeDXV2PoZFCKVfMVoinDq1X7f+fINf/6MfEsW8H5WewTelA64p+z/ma00UlLEDEE8FG2OwjO7Z
tp=PEAHuFZX5cmXU4uHg0+OwaOYLNZlfzzQKv2QKQwtQcupxGOS8UPhVr0EEUj9sVQ/4+VuKEKXZ7VvnQC98gnaZa7Qiyd1NpvRc/7Vjc2xUUCsj5rVkNz8pa4clpxZ96fmJXhe43zKlnH9H+WCbjjUAeIFXyB38W+BZwvwQ2qiM3w4n8lNWY/wHKuOAvJcuHuXpI82n9NF0W2V3piYlNGlUR9Iq4+7CZnrU8cxqe8X4IXmroyo7g5RtkF5nKQs=
001003:0020 DEBUG: Code 5 at h97u/P'k6LzLo#gYp;Jg:29394758
tp=Pq46/YRAB7hWV+XJl1OLh4NPjsGjmCzWZX880Cr9kCkMLUHLqcRjkvFD4Va9BBFI/bFUP+PlbihCl2e1b50AvfIJ2mWu0IsndTab0XP+1Y3NsVFArI+a1ZDc/KWuHJacWfen5iV4XuN8ypZx/R/lgm441AHiBV8gd/FvgWcL8ENqojN8OJ/JTVmP8ByrjgLyXLh7l6SPNp/TRdFtld6YmJTRpVEfSKuPuwmZ61PHManvF+CF5q6MqO4OUbZBeZykL
tp=PI9P/b0mtNn3my+tMln4yoP2VYGKxDEpO84US/F+WB2VosXQZ3qDfte2jU4xBlT3nZFW0gQK2V2u+mrpZdTytVn7VhUCfte4wHoijf5OAFAFlkstKHGqiHjEijS27Nfkx+9XMEDBe9TislK/Qn/opNAJT7/9KxL7mg4RjYAJZKde0oI+fR9CtuSGP4nEp7MhChW5+Qtg+iKk3PWKkF/ui4PXkUxSAgh8abtzYql5pSpIbLAwOPdoQEGnGLnc=
001003:0020 DEBUG: Code 6 at h97u/P'k6LzLo#gYp;Jg:29394758
tp=PKI5eYiPT/29JrTZ95svrTJZ+MqD9lWBisQxKTvOFEvxflgdlaLF0Gd6g37Xto1OMQZU952RVtIECtldrvpq6WXU8rVZ+1YVAn7XuMB6Io3+TgBQBZZLLShxqoh4xIo0tuzX5MfvVzBAwXvU4rJSv0J/6KTQCU+//SsS+5oOEY2ACWSnXtKCPn0fQrbkhj+JxKezIQoVufkLYPoipNz1ipBf7ouD15FMUgIIfGm7c2KpeaUqSGywMDj3aEBBpxi53
tp=PJAuycdeFoDXtFpSawzkpMEe5mGygE81NtSSRQ9JuDHmkpoWaJ7+a+mkbC3cHtnvae76G5LiSFoD/2Ohi9f4IU4uFJrjV+tOHT0n0JTRzpcKOU+NZpg0HOvBNcK492ygrq4CMOIeHey//XkfIE2mADLMRKxIaZZpLt2X3XcVzmnYR1sH2KIUxDpbXNxWlVZc8SPxCHKNWXN2UaA4W7A43YA8uSpzXrRO2QYZ6B/IZr/tbEAII0kjBydd3OXc=
001003:0020 DEBUG: Code 7 at h97u/P'k6LzLo#gYp;Jg:29394758
004004:0000 The source file '/BDMV/STREAM/00075.m2ts' is corrupt or invalid at offset 32222533632, attempting to work around
004007:0010 AV synchronization issues were found in file 'file://D:/Video/The Lord of the Rings- The Return of the King/The Lord of the Rings- The Return of the King-FPL_MainFeature_t01.mkv' (title #2)
004047:0010 AV sync issue in stream 0 at 1:10:36.232 : secondary stream video frame timecode differs by +166.833ms
THDSF: [truehd @ 00000107D081DD60] End of stream indicated.
004047:0010 AV sync issue in stream 0 at 3:21:01.758 : video stream has 1 frames with invalid timecodes
004047:0010 AV sync issue in stream 5 at 0:00:00 : Forced subtitles track #5 turned out to be empty and was removed from output file
004047:0010 AV sync issue in stream 7 at 0:00:00 : Forced subtitles track #7 turned out to be empty and was removed from output file
004047:0010 AV sync issue in stream 9 at 0:00:00 : Forced subtitles track #9 turned out to be empty and was removed from output file
002023:0000 Encountered 2 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/
error=0x070B0D08 count=2 name=Internal error - M2TS hash check failed (3336)
005005:0080 1 titles saved
Re: Two New UHD Sets of LOTR Problems
#2 Post by MartyMcNuts » Wed Feb 04, 2026 3:33 am
kingpeep wrote: Wed Feb 04, 2026 3:14 am I have attached two logs to this post around some issues I am receiving trying to make digital backups of Lord of the Rings (Theatrical and Extended). I have read through the forums that this is a known problematic UHD set. So I expected that I would run into issues, but in my first case, I was only able to rip one of the six discs.
OS device name: F:
Revision: 1.02
Disc Information
Number of layers: 3
I don't see a question anywhere???
Yes, the LotR boxset is notoriously bad. It also doesn't help your case that you are using a LG drive. Often people have had to replace the set multiple times to get all discs successfully ripped.
All you can do is continue to clean the discs and use a better drive (Pioneer) if you can.
kingpeep
#3 Post by kingpeep » Wed Feb 04, 2026 4:01 am
Thanks Marty. I did look into this and saw on other posts that a Pioneer drive was more reliable.
I also saw something about how Pioneers bought in retail stores no longer can be flashed back to the firmware required to consistently rip or simply don't allow flashing of old firmware any further. So I was hesitant on purchasing a Pioneer, but it sounds like I need to.
I'll have to check the UHD drives page and find a reliable model I can still purchase. If you have any recommendations let me know!
#4 Post by MartyMcNuts » Wed Feb 04, 2026 4:11 am
kingpeep wrote: Wed Feb 04, 2026 4:01 am Thanks Marty. I did look into this and saw on other posts that a Pioneer drive was more reliable.
Good luck!
You'll be hard pressed finding any Pioneer drives in retail stores, unless you look at the Verbatim 43887 (also sometimes the 43890) which usually contains a Pioneer BDR-UD03 that can be cross-flashed for UHD or the ASUS BW-16D1X-U and hope you get a unit with a Pioneer drive inside instead of a LG drive.
If you didn't already know, Pioneer ceased manufacturing optical drives back in 2024 and closed the Pioneer store in April 2025. Pretty much all existing stock around the world is gone.
Asmcom and Billycar11 have some Pioneer drives available. I've sold out of Pioneer models and only have the Verbatim 43887 (Pioneer BDR-UD03 cross-flashed to BDR-UD04 firmware for UHD compatibility) available.
Even with a Pioneer, there's still no guarantee you will get those LotR discs ripped! They are just the absolute worst quality UHD discs ever!
