Windows Explorer Crash
Monkeylord
Not sure where I can look on my system for any more info, and Google hasn't helped at all.
Every time I use MakeMKV, Windows Explorer (Win 11) crashes at least once. Usually more though. I don't see any problems until I try and make the taskbar appear or open a new file explorer window. At that point nothing hapens unless I repeatedly click on a blank part of the desktop or spam the windows key on my keyboard. After a few seconds windows explorer shuts down and restarts (screen flashes black then white then back to my wallpaper) and any open programs end up in a different order.
It's not a huge problem, but it is supremely annoying and only happens when I use MakeMKV so I'm convinced it's being caused by some compatibility issue or another. This never happened when I was running Win 7 or Win 10. Trying to run in various compatibility modes do not help, however.
Am I alone in this and does anyone have a potential solution? Happy to provide any info that I can.
Re: Windows Explorer Crash
I've had the same issue since forever - I usually just restart explorer.exe after using makemkv out of habit.
Test your memory. Failing memory can cause many strange problems. And in my experience web browsers are real sensitive to bad memory (probably because they are memory hogs)
Donno if it is memory related - I remember going for many, many passes of memtest since I've setup my rig (without fail) & only makemkv does this. Mild inconvenience at worst for me to restart explorer.exe
Memory can fail. Just because it was working 6 (or whatever) months ago does not mean that it hasn't failed since.
I've experienced it on two different systems with Windows 11 having file explorer hang after USING (not just launching, but doing active work on a disk). Maybe it happens after I specifically read more than 1 disk, sometimes not. It isn't guaranteed, but it is fairly consistent. Replicated with ddr4, one with ddr5, different disk readers on both, both systems have no issues with any other application, but fairly recently passed memtest. BIOS up to date on both (this happened on any bios version I've had). This happens regardless of overclocking, undervolting, or running stock (including with XMP disabled). The amount of tinkering I do is why I'm confident that it ain't a memory issue. No WHEAs logged when it happens either.
I'm a touch to lazy to pull third system and/or fourth system that have ecc ddims (ddr4 & 5 respectively as well), move over a disk reader, tossing windows 11 onto a system, and test further.
I'm just going to straight blame windows file explorer for being lack-luster and having some sort of panic after MakeMKV has its way with Drive G:, or whatever the reader is on. I don't remember having this problem with Windows 10.
IMO, just Ctrl+Shit+ESC, go to details, restart explorer.exe after ripping a disk & skip it crashing preemptively is the easy workaround.
I'm am/was having this exact same issue with Windows 10. Decided to "upgrade" to Windows 11 and I'm seeing the same issue... I tried to above recommended tests and still no resolution. Anyone ever get to the bottom of this?
I have this issue also.
It seems MakeMKV is not releasing the discs correctly, or something happens that makes this fail.
When I eject on the MakeMKV button it sometimes will not release.
You can see this in the file explorer in Windows. Finally it locks, crashes and restarts when you press
the screen.
The only way for me to fix it is to eject the discs through Windows. If I remember correctly, also
close the MakeMKV connected to the drive that has been locked.
the screen.
Watcherine
This is literally the ONLY reason I have NOT purchased this software!
However, I will say since this software is the only choice for people who wish to archive their purchased 1080p and 4K Blu-ray discs, it is well worth the asking price.
Hey guys. I'm also having this problem on Windows 11. Even after the update to 1.18.3, it's still occurring.
Watcherine
The only thing I saw worth trying is to limit the RAM usage, but I haven't had a chance to try it as I only use the Beta and it hasn't been updated, yet.Tartcore wrote: Tue Feb 03, 2026 12:12 pm Hey guys. I'm also having this problem on Windows 11. Even after the update to 1.18.3, it's still occurring.
This was the suggestion to prevent MakeMKV crashing Windows Explorer from Google's AI, and it could be an old issue, but you never know until you try:
I'm pretty sure this will make the program run slower, but it just might prevent Windows explorer from crashing. If it allows you to, maybe even select a few GBs lower than your actual RAM limit so it doesn't completely use all of it, and see if it helps!Limit RAM usage in MakeMKV by adjusting the read buffer size in Preferences -> IO, changing it from "Auto" to a lower value such as 1024 (1GB) or lower.
Please report back with your results.
Unfortunately, same results. It was already on 1024, but then I tried dropping it to 768 and it kept happening during my rips. I will keep tinkering with these settings and report back if anything worked or fixed the issue.Watcherine wrote: Tue Feb 03, 2026 9:55 pmThe only thing I saw worth trying is to limit the RAM usage, but I haven't had a chance to try it as I only use the Beta and it hasn't been updated, yet.Tartcore wrote: Tue Feb 03, 2026 12:12 pm Hey guys. I'm also having this problem on Windows 11. Even after the update to 1.18.3, it's still occurring.
Watcherine
Thanks for the update!Tartcore wrote: Wed Feb 04, 2026 11:59 am Unfortunately, same results. It was already on 1024, but then I tried dropping it to 768 and it kept happening during my rips. I will keep tinkering with these settings and report back if anything worked or fixed the issue.
I also thought I'd mention that I'm not as faithful with Windows Updates and updating drivers and other computer maintenance like everyone else, so maybe that's a common denominator if you are as well?
I'm just trying to find something outside of the program that could explain why Explorer is only crashing for a few people, but not everyone else.
This happens on a daily basis for me when I try and copy a file from one folder to another on the same drive, or to another drive. It also happens when I'm attempting a conversion to mp4 (using Prism Video File Converter at the moment on Windows 11). It's so bad, I have power down and reboot. This is the second system I've had the problem on. I get it working on USB external hard drives and internal SSD, does not seem to matter. Searching around on the internet the fix suggestions I see range from installing cccp to don't use mkv files because Windows has a problem with them ??? I'm just Joe Average User, this is killing me. Gonna hunt up another converter but that doesn't help the Windows Explorer Crash.
Watcherine
What I just now realized is we haven't mentioned what UHD friendly drive we have, as this could be the common denominator/culprit!
I have the ASUS BW-16D1HT and Windows Explorer just crashed while using CloneBD with already unprotected discs, so I believe this just might be BD-RW drive-related!
UPDATE: I have invalidated this theory with the simple fact that my other installed BD-RW drive similarly crashes, so this is definitely something involving the MakeMKV program that might have somehow been circumvented by possible Windows driver updates, or something similar, on other people's machines who aren't plagued by this phenomenon.
