jjgarcia wrote: Fri Jan 30, 2026 9:08 pm Hey everyone,
My Pioneer drive sometimes is unable to rip certain blurays.
Is there a firmware flash for the libreDrive?
Is this related to also the ability to read UHD discs or is that something else?
Any help would be much appreciated. Here is my drive info from MakeMKV
Thanks in advance,
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Serial number: PBDL028907UC
Firmware date: 2014-12-26
Highest AACS version: 70
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
jjgarcia
Any tips or suggestions on how to flash this drive? Thanks again...
comadose
PM sent.jjgarcia wrote: Mon Feb 02, 2026 4:43 pm Any tips or suggestions on how to flash this drive? Thanks again...
Thanks in advance,
Revision: 3.01
Simplemitch
1st time poster here, so sorry if this should be it's own thread but it seemed relevant and hadn't seen discussed here.
Would there be any reason one WOULDN'T want to flash their drive? I just want to make sure there's no hidden gotchas or that I'm not gonna gain functionality in MakeMKV, but lose functionality elsewhere.
My current drive is an LG WH16NS40 on FW 1.05 (so I'd be going to DE_LG_WH16NS40-NS50_1.02)*. I primarily use it to rip BD/DVD via MakeMKV and to rip CDs via iTunes. On increasingly rare occasions I will burn DVDs and CDs.
I also have a mountain of spare 5.25" DVD/CD burners so I could always just add an extra drive if need be.
Thanks.
*side question: Do I need to verify it says NS50 on it before flashing? It'd be a bear to get to it in the PC that it's in...
Thanks.
No. Flash to WH16NS60 1.02. No sleep bug and works better with UHDs.Simplemitch wrote: Wed Feb 04, 2026 5:44 pm 1st time poster here, so sorry if this should be it's own thread but it seemed relevant and hadn't seen discussed here.
Thanks.
Simplemitch
I assume you mean the DE_LG_WH16NS60_1.02_MK file. And that's OK even though I have a 40, not a 60, correct?Coopervid wrote: Wed Feb 04, 2026 7:30 pmNo. Flash to WH16NS60 1.02. No sleep bug and works better with UHDs.Simplemitch wrote: Wed Feb 04, 2026 5:44 pm 1st time poster here, so sorry if this should be it's own thread but it seemed relevant and hadn't seen discussed here.
Thanks.
Sorry for being paranoid; I like leaving NOTHING to chance.
Not DE. It's in the OLD folder of the firmware pack. It will work.Simplemitch wrote: Wed Feb 04, 2026 7:51 pmI assume you mean the DE_LG_WH16NS60_1.02_MK file. And that's OK even though I have a 40, not a 60, correct?Coopervid wrote: Wed Feb 04, 2026 7:30 pmNo. Flash to WH16NS60 1.02. No sleep bug and works better with UHDs.Simplemitch wrote: Wed Feb 04, 2026 5:44 pm 1st time poster here, so sorry if this should be it's own thread but it seemed relevant and hadn't seen discussed here.
Thanks.
Simplemitch
See! Glad I asked!Coopervid wrote: Wed Feb 04, 2026 8:42 pmNot DE. It's in the OLD folder of the firmware pack. It will work.Simplemitch wrote: Wed Feb 04, 2026 7:51 pmI assume you mean the DE_LG_WH16NS60_1.02_MK file. And that's OK even though I have a 40, not a 60, correct?Coopervid wrote: Wed Feb 04, 2026 7:30 pm
But.... there is no "OLD" folder in the All you Need Firmware Pack that I downloaded today and I don't see any links to prior releases. It just has two folders ("Internal Desktop Drives" and "Slim External Drives") each containing nothing but bin files
This is the link I used:
https://www.mediafire.com/file/rak1mk0p ... 9.zip/file
from this page:
viewtopic.php?f=16&t=22896
Have a link to the old one, by chance?
Yes, that is the correct file: DE_LG_WH16NS60_1.02_MKCoopervid wrote: Wed Feb 04, 2026 8:42 pmNot DE. It's in the OLD folder of the firmware pack. It will work.Simplemitch wrote: Wed Feb 04, 2026 7:51 pmI assume you mean the DE_LG_WH16NS60_1.02_MK file. And that's OK even though I have a 40, not a 60, correct?Coopervid wrote: Wed Feb 04, 2026 7:30 pm
Also, yes, you must ensure the drive says SVC NS50 on the label, is manufactured after 2015 and has the MT1959 drive platform.
icefloe
Just popping in to say thank you!! My LG WH16NS40 from 2020 arrived today and in just minutes had it flashed. As soon as I saw that it could in fact read UHD disks I registered MakeMKV and it's now ripping a UHD disk. My Ugreen 8 bay NAS is going to get a workout too. lol
mkvuser190
Hi all
I'm new to this forum, and I am very confused by this thread. I don't see my drive or firmware listed, but people in another thread have helped others with the same drive. I have a Pioneer drive, and I am scared to brick it if I do something wrong. Could somebody tell me if my drive is flashable for UHD? Thank you.
Also, I'm sorry for essentially re-posting this from another thread. I just think this one is more active than the other one.
OS device name:
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number:
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 63
Drive platform: RS8D30
Firmware version: 1.03
NobleOccum
I'm flashing my drive following the guide in the original post of this thread. Everything seems to go through fine, but MakeMKV doesn't see the drive as any different from how I started, and UHD disks still get ejected.
My drive info from MakeMVK:
And the output from my command:Drive Information
Product: BD-RE WH14NS40
Revision: 1.05
Serial number:
Highest AACS version: 82
Harware support: Yes
Firmware support: No
Firmware version: 1.05
./makemkvcon f -d '/IOBDServices/AEFAD468' -f /Users/user/Downloads/sdf.bin rawflash main -i /Users/user/Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/WH16NS60/HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin
Reading input file /Users/user/Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/WH16NS60/HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin
Current Drive ID: HL-DT-ST_BD-RE__WH14NS40_1.05_212005061444_KLEO5OD3538
yes
100% Operation finished
Done successfully
You need to post your own Makemkv info to be helped.mkvuser190 wrote: Fri Feb 06, 2026 6:12 am Hi all
I'm new to this forum, and I am very confused by this thread. I don't see my drive or firmware listed, but people in another thread have helped others with the same drive. I have a Pioneer drive, and I am scared to brick it if I do something wrong. Could somebody tell me if my drive is flashable for UHD? Thank you.Also, I'm sorry for essentially re-posting this from another thread. I just think this one is more active than the other one.Code: Select all
Drive Information OS device name: Manufacturer: PIONEER Product: BD-RW BDR-XD07 Revision: 1.03 Serial number: Firmware date: 2020-08-20 Bus encryption flags: 13 Highest AACS version: 63 LibreDrive Information Status: Enabled Drive platform: RS8D30 Firmware name: PIONEER BDR-BDS7 Firmware type: Original (unpatched) Firmware version: 1.03 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
You need to replace main with enc in your command.NobleOccum wrote: Mon Feb 09, 2026 4:47 pm I'm flashing my drive following the guide in the original post of this thread. Everything seems to go through fine, but MakeMKV doesn't see the drive as any different from how I started, and UHD disks still get ejected.
My drive info from MakeMVK:And the output from my command:Drive Information
Revision: 1.05
Serial number:
Unrestricted read speed: Possible (with patched firmware)Code: Select all
./makemkvcon f -d '/IOBDServices/AEFAD468' -f /Users/*/Downloads/sdf.bin rawflash main -i /Users/*/Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/WH16NS60/HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin Reading input file /Users/*/Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/WH16NS60/HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin Flashing flags = 0x0 : 0 0 0 0 : ---- ---- ---- ---- Current Drive ID: HL-DT-ST_BD-RE__WH14NS40_1.05_212005061444_KLEO5OD3538 Ready to write drive flash memory. Type "yes" to continue, "no" to abort yes Operation started: Sending flash image to drive 100% Operation finished Operation started: Programming flash 100% Operation finished Done successfully
