E.T. extra-terrestrial UHD disk (ET40TH_UPK5) : never stop analysing the disk, too many sync errors
brurab
Post by brurab »
When I try to rip the UHD E.T Extra-terrestrial (ET40TH_UPK5), I got stuck in the initial analysis phase (after decryption that seems ok) when makemkv tries to get all the pieces of videos and audio. In the list of events displayed in the makemkv window , I have lots AV sync error and I finally get stuck on file 00134 with. I have no other info from makemkv, the disk is still read but after 30mn waiting I did not get the end of the analysis.
I get the disk replaced but still the same behaviour.
And my multimedia player can read it from start to end of the film.
Anyone else get the same problem ?
Re: E.T. extra-terrestrial UHD disk (ET40TH_UPK5) : never stop analysing the disk, too many sync errors
Have you tried gently cleaning the disc? Often even brand new discs benefit from cleaning.
brurab
Post by brurab »
Thanks for your reply, and yes I always clean the disk before ripping it. But does not change the error.
