confirm correct firmware
sp9233
Post by sp9233 »
hello
I want to confirm the correct firmware before flashing.
Hardware:
- Drive: LG BU40N (slim)
- Connected via USB external enclosure (Archgon MD-8107S-U3YC-UHD)
- OS: Windows 11
- MakeMKV version: 1.18.3
Current behavior:
- UHD discs detected but fail with AACS errors
- MakeMKV does NOT report LibreDrive enabled
I have downloaded the “all you need firmware pack” and see the LG slim BU40N folder.
Before flashing anything, I want to confirm:
1) Which exact firmware file is recommended for BU40N in a USB enclosure on Windows 11
2) Whether this drive requires a RECOVER step first or can be flashed directly
3) That I should NOT crossflash with BP50NB40 or BP60NB10 firmware
I’m intentionally stopping here to avoid bricking the drive.
Thanks in advance.
Re: confirm correct firmware
new archgons cant be flashed in the case and libredrive also wont work in them for not either
Billycar11 wrote:
Tue Feb 03, 2026 1:00 am
Billy, in your guide you mention that the new Archgon doesn't support flashing but you don't mention that it also prevents Libredrive. Maybe you should do an addendum for that issue.
