Easy A (2010) Blu-ray skips main title
pennant
Post by pennant »
I have a US retail Blu-ray copy of Easy A (2010). MakeMKV skips the first playlist because it is equal to playlist 30. However, playlist 1 has 16 chapters and is the correct title. Playlist 30 has 106 chapters. Playlist 1 should be the one displayed, not playlist 30.
I'm running MakeMKV 1.7.2 on Mac OS X 10.7.3. Please let me know if more information is needed.
jrknn7
Re: Easy A (2010) Blu-ray skips main title
Post by jrknn7 »
Same problem...
File 00099.mpls was added as title #0
File 00001.mpls was added as title #1
Title #00102.mpls has length of 60 seconds which is less than minimum title length of 119 seconds and was therefore skipped
Title #00999.mpls has length of 60 seconds which is less than minimum title length of 119 seconds and was therefore skipped
Title 00095.mpls is equal to title 00099.mpls and was skipped
Title 00096.mpls is equal to title 00099.mpls and was skipped
File 00006.mpls was added as title #2
Title #00007.mpls has length of 74 seconds which is less than minimum title length of 119 seconds and was therefore skipped
File 00008.mpls was added as title #3
File 00009.mpls was added as title #4
File 00010.mpls was added as title #5
File 00011.mpls was added as title #6
File 00012.mpls was added as title #7
File 00030.mpls was added as title #8
Title #00000.m2ts has length of 14 seconds which is less than minimum title length of 119 seconds and was therefore skipped
Title #00081.m2ts has length of 60 seconds which is less than minimum title length of 119 seconds and was therefore skipped
Title #00082.m2ts has length of 0 seconds which is less than minimum title length of 119 seconds and was therefore skipped
Title #00083.m2ts has length of 0 seconds which is less than minimum title length of 119 seconds and was therefore skipped
Title #00104.m2ts has length of 42 seconds which is less than minimum title length of 119 seconds and was therefore skipped
Title #00502.m2ts has length of 5 seconds which is less than minimum title length of 119 seconds and was therefore skipped
Title #00503.m2ts has length of 5 seconds which is less than minimum title length of 119 seconds and was therefore skipped
Title #00504.m2ts has length of 5 seconds which is less than minimum title length of 119 seconds and was therefore skipped
Title #00205.m2ts has length of 5 seconds which is less than minimum title length of 119 seconds and was therefore skipped
Title #04999.m2ts has length of 30 seconds which is less than minimum title length of 119 seconds and was therefore skipped
Title #00021.m2ts has length of 1 seconds which is less than minimum title length of 119 seconds and was therefore skipped
Title #00022.m2ts has length of 60 seconds which is less than minimum title length of 119 seconds and was therefore skipped
Title #00101.m2ts has length of 42 seconds which is less than minimum title length of 119 seconds and was therefore skipped
File 00105.m2ts was added as title #9
File 00106.m2ts was added as title #10
File 00107.m2ts was added as title #11
File 00108.m2ts was added as title #12
Title #00115.m2ts has length of 5 seconds which is less than minimum title length of 119 seconds and was therefore skipped
Title #00116.m2ts has length of 60 seconds which is less than minimum title length of 119 seconds and was therefore skipped
Title #00117.m2ts has length of 62 seconds which is less than minimum title length of 119 seconds and was therefore skipped
File 00118.m2ts was added as title #13
File 00119.m2ts was added as title #14
File 00120.m2ts was added as title #15
File 00121.m2ts was added as title #16
File 00122.m2ts was added as title #17
File 00123.m2ts was added as title #18
File 00124.m2ts was added as title #19
File 00125.m2ts was added as title #20
File 00126.m2ts was added as title #21
Title #00127.m2ts has length of 94 seconds which is less than minimum title length of 119 seconds and was therefore skipped
Title #00129.m2ts has length of 13 seconds which is less than minimum title length of 119 seconds and was therefore skipped
Title 00001.mpls is equal to title 00030.mpls and was skipped
jrknn7
Post by jrknn7 »
Solution: "This is unfortunately a known problem. The only workaround available is a bit lengthy:
1. Make a full disc backup with MakeMKV, encrypted or decrypted, doesn't matter
2. Navigate into backup folder, then into BDMV, PLAYLIST and delete the file 00030.mpls
3. Open produced backup with MakeMKV and make MKV out of it."
