PM sent.guilheb wrote: Wed Dec 24, 2025 5:09 am Drive Information
Manufacturer: PIONEER
Product: BD-RW BDR-XS07
Revision: 1.01
Serial number: *****
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 16
Drive platform: RS8E20
Firmware version: 1.01
BDR-XS07S UHD Flash
Re: BDR-XS07S UHD Flash
Afternoon, Coopervid, could you take a look at the specs for BDR-XS07S and let me know if it can be flashed to rip UHD:
Revision: 1.01
Serial number: TKDL003670UC
Highest AACS version: 77
No rush, just hoping I can get it ripping alongside my XS07UHD
Revision: 1.01
PM sent.dlowhorn wrote: Sat Jan 31, 2026 8:05 pm Afternoon, Coopervid, could you take a look at the specs for BDR-XS07S and let me know if it can be flashed to rip UHD:
Revision: 1.01
mkvuser190
Hi Coopervid, I would also like to flash my drive for UHD:
Thank you very much for your assistance.
OS device name:
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number:
Firmware date: 2020-08-20
Highest AACS version: 63
Drive platform: RS8D30
Firmware version: 1.03
Unrestricted read speed: Yes-
striker-pxs
Hello Cooper Vid and community, I also have a BDR-XS07S that should have older enough firmware to support flashing, looking for assistance if possible.
Thanks for any help!
OS device name: F:
Revision: 1.01
Serial number: TKDL003458UC
Highest AACS version: 50
Sure just email me that drive info section see below for emailstriker-pxs wrote: Sat Feb 14, 2026 10:09 pm Hello Cooper Vid and community, I also have a BDR-XS07S that should have older enough firmware to support flashing, looking for assistance if possible.
Thanks for any help!Code: Select all
Drive Information OS device name: F: Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-XS07 Revision: 1.01 Serial number: TKDL003458UC Firmware date: 2020-09-03 Bus encryption flags: 13 Highest AACS version: 50 LibreDrive Information Status: Enabled Drive platform: RS8E20 Firmware name: PIONEER BDR-BDS7 Firmware type: Original (unpatched) Firmware version: 1.01 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Hi, I have a Pioneer BDR-XS07S with firmware revision 1.01. I'd like to patch it for 4k ripping but can't seem to find where to download the firmware. Any help would be appreciated.
Sure email me that drive info section see below for emailadriaticC wrote: Mon Mar 16, 2026 2:31 am Hi, I have a Pioneer BDR-XS07S with firmware revision 1.01. I'd like to patch it for 4k ripping but can't seem to find where to download the firmware. Any help would be appreciated.
For all others there is no need to post your makemkv drive info section publicly just email it to me directly
Hello, and happy belated new year! Is there any update on the status of compatibility for drives with post-2020 firmware? Is such compatibility still being worked on? Cheers!
• LG WH16NS60 (x2)
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• PANASONIC SW-9576-C
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
post 12/22+Voxelium wrote: Mon Mar 16, 2026 9:01 am Hello, and happy belated new year! Is there any update on the status of compatibility for drives with post-2020 firmware? Is such compatibility still being worked on? Cheers!
i have a fix for it im doing a trial now on new pioneer fw email me for it see below
for now i do have to connect to your pc to do it but it will be automated soon
Hi, thanks for the quick response! Yes, I meant 2022, not 2020. Thank you for the correction. I will be sending you an email shortly. Thank you for everything you’ve contributed!Billycar11 wrote: Mon Mar 16, 2026 9:05 ampost 12/22+Voxelium wrote: Mon Mar 16, 2026 9:01 am Hello, and happy belated new year! Is there any update on the status of compatibility for drives with post-2020 firmware? Is such compatibility still being worked on? Cheers!
• LG WH16NS60 (x2)
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
• LG GGW-H20L (x3)
• LG BU40N
• LG GH40F
• LITE-ON IHAS524B
• PIONEER BDR-S11JX
• PIONEER BDR-XS07S
• PIONEER BDR-UD04
• IMATION LS120
• IOMEGA Z250ATAPI
• IOMEGA Z750ATAPI
• FUJITSU MDD3064AP
• FUJITSU M2553K03B
Hi, I just registered and can't send PMs yet but I was directed here because I have the below drive and was told it can be flashed to enable UHD Blu-ray support. Any help would be appreciated. Thanks!
OS device name: H:
Revision: 1.01
Serial number: ADDL005723UC
Hello
I'm looking to flash my drive so I can rip UHD discs, can anyone help?
OS device name: E:
Product: BD-RW BDR-XS07U
Revision: 1.02
Serial number: CBDL008388UC
Firmware date: 2022-10-24
Drive platform: RS8E21
Firmware version: 1.02/ID05
OS device name: E:
Revision: 1.02
This shouldn't need flashing. Have you tried a UHD disc yet?bkwashby wrote: Sat Apr 18, 2026 10:44 pm Hello
OS device name: E:
Revision: 1.02
Yes, when I try to load the disc it fails.MartyMcNuts wrote: Sun Apr 19, 2026 7:45 amThis shouldn't need flashing. Have you tried a UHD disc yet?bkwashby wrote: Sat Apr 18, 2026 10:44 pm Hello
OS device name: E:
Revision: 1.02
