UHD Abbruch nach ca. 35 Minuten
Aika300
Post by Aika300 »
Hallo, ich habe eine Frage . Wenn ich große Dateien ab ca. 60 Mb. Rippe erfolgt jedesmal bei ungefähr 50% ein Abbruch mit dem Hinweis fehlgeschlagen. Bis 60 Mb ist das kein Problem. Wo liegt der Fehler.
Aika300
Google Translate wrote:Hello, I have a question. When I rip large files (around 60 MB or larger), the process always stops at about 50% with a "failed" message. This works fine for files under 60 MB. What could be causing this?
Aika300
Re: UHD Abbruch nach ca. 35 Minuten
60mb is a very small file; a typical 25 minute Bluray is almost 10 times that size.
The error sounds like you are hitting a limit on your system for where you are trying to WRITE the file. When it fails, the system frees up the space that it was using for the write. Could you be writing to a much smaller drive than you think you are?
Aika300
Post by Aika300 »
Hallo, Fehler beim ablesen. Die Datei ist ca. 60 000 Mb groß. Die Platte hat 16 tb und ist nur halb gefüllt. Kleinere Datenmengen werden problemlos eingelesen. Die Scheibe ist nicht defekt, im Player läuft sie durch.
Aika
Google Translate wrote:Hello, there's an error reading the file. It's about 60,000 MB. The hard drive has 16 TB of storage and is only half full. Smaller amounts of data are read without any problems. The disc isn't defective; it plays through in the player.
Aika
Posting the log from the event would help. We cannot tell if the error is because the drive you are writing to is being considered "full" or because the disk you are reading is not being read.
Bombart
Post by Bombart »
Wie ist die Platte formatiert?
Google Translate wrote:How is the disk formatted?
