gock01
Post
by gock01 » Sat Jan 31, 2026 7:17 am
I purchased a Verbatim Ultra HD 4K Blu-ray player with the model code KIAB and serial number 43888. When I launch MakeMkv (v1.18.3 [win(x64-release]]), it gives me the following information:
OS device name: F:
Product: BD-RE BU40N
Revision: 1.05
Serial number: ***
Highest AACS version: 76
Should I flash it?
How can I flash it without causing an irreversible error ?
For your information, I put a Blu-ray in the drive, and after playing it with MakeMkv, I get the following error:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Saved AACS dump file as C:\Users\ERIC/.MakeMKV/MKB20_v76_Elvis_E891.tgz
Thank you for your help
Post
by MartyMcNuts » Sat Jan 31, 2026 9:40 am
gock01 wrote: Sat Jan 31, 2026 7:17 am
OS device name: F:
Revision: 1.05
Serial number: ***
Should I flash it?
You need to flash it to BU40N 1.03-MK to enable libredrive. Just do it. It's extremely easy.
gock01
Post
by gock01 » Sat Jan 31, 2026 10:07 am
MartyMcNuts wrote: Sat Jan 31, 2026 9:40 am
OS device name: F:
Revision: 1.05
Serial number: ***
Should I flash it?
Thank you.
Is there a risk that I could render the player unusable if it malfunctions?
If so, can I revert to version 1.05?
Is this procedure on this site suitable?
https://github.com/nxyzo/Flashing-Verba ... -to-1.03MK
Can I use the file it provides?
Thank you.
Post
by Coopervid » Sat Jan 31, 2026 10:58 am
gock01 wrote: Sat Jan 31, 2026 10:07 am
OS device name: F:
Revision: 1.05
Serial number: ***
Should I flash it?
Thank you.
Thank you.
viewtopic.php?f=16&t=22896&hilit=SDFTool
To revert it you can use the official LG flasher.
gock01
Post
by gock01 » Sat Jan 31, 2026 1:43 pm
To flash it, can I follow the procedure described on this site ?
Can I use the provided file to flash my player ?
If not, how can I do it?
Thank you
gock01
Post
by gock01 » Sat Jan 31, 2026 3:16 pm
I'm continuing my search for how to flash my player. The forum is very comprehensive, but I'm having trouble finding what I need.
I'm looking for the file I need to flash my player.
But I can't find it anywhere on the forum.
If I understand correctly, then I just need to do it like this.
- Close MakeMKV
- Open Command Prompt as Administrator
Navigate to the MakeMKV installation directory:
cd "C:\Program Files (x86)\MakeMKV"
Execute the firmware flashing command:
makemkvcon64.exe f --all-yes -d X: rawflash enc -i "PATH_TO_FIRMWARE_FILE"
(Replace X: with your optical drive letter and PATH_TO_FIRMWARE_FILE with the full path to the .bin file)
Please tell me if this is correct and correct me if I'm wrong.
As a reminder, here's the information provided by MakeMKV. .
OS device name: F:
Revision: 1.05
Serial number: ******
Post
by Coopervid » Sat Jan 31, 2026 5:34 pm
gock01 wrote: Sat Jan 31, 2026 3:16 pm
- Close MakeMKV
OS device name: F:
Revision: 1.05
Are you a troll??? You should have read my answer above and not open new threads!!!
gock01
Post
by gock01 » Sat Jan 31, 2026 6:15 pm
Coopervid wrote: Sat Jan 31, 2026 5:34 pm
- Close MakeMKV
OS device name: F:
Revision: 1.05
Sorry, that was my mistake.
Skyynet
Post
by Skyynet » Fri Oct 30, 2026 10:35 am
I bought the same Verbatim drive with BU40N and Model Code KIAB. I read a lot about problems, which appears misleading. I just flashed it on macOS. Sharing, what I did for reference.
- Install MakeMKV in Applications folder
- Download The All You Need Firmware Pack
- Copy HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934 into /Applications/MakeMKV/Contents/MacOS/
- Download https://makemkv.com/sdf.bin
- Copy sdf.bin into /Applications/MakeMKV/Contents/MacOS/
- Get Drive ID by entering in Terminal /Applications/MakeMKV.app/Contents/MacOS/makemkvcon f -l
- note: Drive ID 08154711 taken as example in next command line. Use yours.
- Flash with command /Applications/MakeMKV.app/Contents/MacOS/makemkvcon f -d /IOBDServices/08154711 -f sdf.bin rawflash enc -i HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
That's it. Copying the files in 3. and 5. can by done easily via Finder. Just go to the MakeMKV icon, rightclick and select "show packet contents". Then just drag and drop the according files. Copying the files into the MakeMKV folder makes the command line shorter, since we don't have to use paths.
Hope, this helps someone
gwhitcombe71
Post
by gwhitcombe71 » Fri Oct 30, 2026 6:07 pm
Skyynet wrote:I just flashed it on macOS. Sharing, what I did for reference.
Cheers Skyynet, nine months late but still beats my pub quiz team's record for turning up
Skyynet
Post
by Skyynet » Sat Oct 31, 2026 1:22 am
Better late than never. I'm sure, in a few months I'll search for this again and find my own post
trevbot
Post
by trevbot » Sat Oct 31, 2026 3:15 pm
Skyynet, there's a missing space before -f in the flashing command:
Use your own drive ID in place of 08154711.
I build
trev.bot. LG & Pioneer drive flashing for Windows, macOS and Linux.
Skyynet
Post
by Skyynet » Sat Oct 31, 2026 6:24 pm
You're right about the missing space. Happened, when I anonymized the drive id. I corrected it in the above post of mine.
Entering one's own drive id instead of 08154711 was already mentioned in 7.
