Hi. My LG BP50NB40 has just arrived, and it's reading a red cross next to "MT1959 Platform:" in SDFtool
Obviously, can't read or write firmware this way. Fix?
LG BP50NB40 - No MT1959?
Re: LG BP50NB40 - No MT1959?
Can you post the info MakeMKV has for your drive?
Lewis M. Tonge
OS device name: F:
Manufacturer: LG
Product: BP50NB40
Revision: 1.00
Serial number:
Highest AACS version: 81
OS device name: F:
Manufacturer: LG
Product: BP50NB40
Revision: 1.00
Serial number:
blind-s33r
If its an 1.00 revision then its is mt1939 and a bu20n internally and unable to flash. Don't try flashing it with the other flashers as it will just brick.
