Unable to rip with Verbatim drive 43888
gock01
Post by gock01 »
I purchased a Verbatim Ultra HD 4K Blu-ray player with the model code KIAB and serial number 43888. When I launch MakeMkv (v1.18.3 [win(x64-release]]), it gives me the following information:
OS device name: F:
Product: BD-RE BU40N
Revision: 1.05
Serial number: ***
Highest AACS version: 76
Should I flash it?
How can I flash it without causing an irreversible error ?
For your information, I put a Blu-ray in the drive, and after playing it with MakeMkv, I get the following error:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Saved AACS dump file as C:\Users\ERIC/.MakeMKV/MKB20_v76_Elvis_E891.tgz
Thank you for your help
Re: Unable to rip with Verbatim drive 43888
gock01 wrote: Sat Jan 31, 2026 7:17 am Hello,
OS device name: F:
Revision: 1.05
Serial number: ***
Should I flash it?
You need to flash it to BU40N 1.03-MK to enable libredrive. Just do it. It's extremely easy.
gock01
Post by gock01 »
MartyMcNuts wrote: Sat Jan 31, 2026 9:40 am
OS device name: F:
Revision: 1.05
Serial number: ***
Should I flash it?
Thank you.
Is there a risk that I could render the player unusable if it malfunctions?
If so, can I revert to version 1.05?
Is this procedure on this site suitable?
https://github.com/nxyzo/Flashing-Verba ... -to-1.03MK
Can I use the file it provides?
Thank you.
gock01 wrote: Sat Jan 31, 2026 10:07 am
OS device name: F:
Revision: 1.05
Serial number: ***
Should I flash it?
Thank you.
Thank you.
viewtopic.php?f=16&t=22896&hilit=SDFTool
To revert it you can use the official LG flasher.
gock01
Post by gock01 »
To flash it, can I follow the procedure described on this site ?
Can I use the provided file to flash my player ?
If not, how can I do it?
Thank you
gock01
Post by gock01 »
I'm continuing my search for how to flash my player. The forum is very comprehensive, but I'm having trouble finding what I need.
I'm looking for the file I need to flash my player.
But I can't find it anywhere on the forum.
If I understand correctly, then I just need to do it like this.
- Close MakeMKV
- Open Command Prompt as Administrator
Navigate to the MakeMKV installation directory:
cd "C:\Program Files (x86)\MakeMKV"
Execute the firmware flashing command:
makemkvcon64.exe f --all-yes -d X: rawflash enc -i "PATH_TO_FIRMWARE_FILE"
(Replace X: with your optical drive letter and PATH_TO_FIRMWARE_FILE with the full path to the .bin file)
Please tell me if this is correct and correct me if I'm wrong.
As a reminder, here's the information provided by MakeMKV. .
OS device name: F:
Revision: 1.05
Serial number: ******
gock01 wrote: Sat Jan 31, 2026 3:16 pm I'm continuing my search for how to flash my player. The forum is very comprehensive, but I'm having trouble finding what I need.
- Close MakeMKV
OS device name: F:
Revision: 1.05
Are you a troll??? You should have read my answer above and not open new threads!!!
gock01
Post by gock01 »
Coopervid wrote: Sat Jan 31, 2026 5:34 pm
- Close MakeMKV
OS device name: F:
Revision: 1.05
Sorry, that was my mistake.
