I have 2 new drives and purchased the Flash tool single drive flasher for both. Neither are seen and I get " Unable to find yourMakeMKV installation". Any suggestions would help. I was able to flash with the SDFtool but still no joy. I have included screen shots.
Processor Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz 3.00 GHz
Installed RAM 32.0 GB (31.8 GB usable)
After SDFtool Flash
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KLHL75E4257
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 3.10
Failed SDFtool Flash with command procedure error Oxff05c103
OS device name: U:
Product: BD-RE BU40N
Revision: 1.02
Serial number: MOFM2QG5610
Firmware version: 1.02
Please help,
Scott
Attempting to Flash for UHD
PandaMac
Re: Attempting to Flash for UHD
Reinstall makemkv to the default directory if it's not
PandaMac
No Change at all.
I've emailed you already about this. I assumed it was sorted as I never heard back from you.
Can you confirm:
1. You are running Windows 10 or 11 (64 bit)
2. You are NOT using a VM
3. You installed MakeMKV in the default directory (which is C:\Program Files (x86)\MakeMKV)
Also, how are your drives connected to your PC? What enclosures or adapters are you using?
moviewatcher22
I am having this same error code, 0xff05c103
Using Win10, makemkv installed on c:, not running a VM. Any help would be appreciated.
According to MakeMKV in your picture, your BU40N is at 1.03 with LibreDrive enabled. Why are you trying to flash it?moviewatcher22 wrote: Sat Jan 31, 2026 2:57 am Hi,
Using Win10, makemkv installed on c:, not running a VM. Any help would be appreciated.![]()
moviewatcher22
Because I don't know what I am doing. It shows up as you see but the drive does not open, the led does not light up. In MakeMKV it won't open when I hit eject. So I was thinking it needs to be flashed, it came this why from who I got it from online.
So what drive is it?moviewatcher22 wrote: Sat Jan 31, 2026 5:29 am Because I don't know what I am doing. It shows up as you see but the drive does not open, the led does not light up. In MakeMKV it won't open when I hit eject. So I was thinking it needs to be flashed, it came this why from who I got it from online.
Make?
Model?
Manufacture date?
Then copy/paste the MakeMKV drive info & libredrive info sections.
That error code normally means there's a disc in the drive. Remove it.
moviewatcher22
It is a lg wh14ns40, product bd-re bu40n, this image has all the info. It won't open for me and MakeMKV says there is no disc.
https://www.flickr.com/photos/189419696 ... 069660621/
moviewatcher22
Revision: 1.03
Serial number: SIK9MG86E1343
Firmware version: 1.03
Revision: 1.03
Who told you to flash bu40n fw to a wh14ns40moviewatcher22 wrote: Sun Feb 01, 2026 1:43 am It is a lg wh14ns40, product bd-re bu40n, this image has all the info. It won't open for me and MakeMKV says there is no disc.
Use the recovery option quick back to the correct fw and don't keep the drive powered on when its flashed wrong
moviewatcher22
I have just been reading the forums and trying to figure it out. The why it is programed is how it came in the mail. I was just trying to flash it not knowing if it was already good or not.
I do not know or understand yet how to make it work. I requested a return from the ebay seller for the drive since it won't open. In theory I am thinking it should just be working like normal at least. I can't afford the preflashed drives yet but really want to back up all of my uhd discs and other older movies with it.
???moviewatcher22 wrote: Sun Feb 01, 2026 4:47 am I have just been reading the forums and trying to figure it out. The why it is programed is how it came in the mail. I was just trying to flash it not knowing if it was already good or not.
it came flashed as a BU40N not a WH14NS40?
not impossible but im thinking you did it not the seller
Szary Kot
Maybe it'll be useful to someone.
On Windows 7 Professional SP2 64-bit, SDFtool works like a charm.
I've used it to convert two drives: a Verbatim 43888 (BU40N) and an Asus BW-16D1HT.
Everything works perfectly. Many thanks to the program's creators.
Licensed User MakeMKV
