Hello. I am brand new to MakeMKV. I just got one of the recommend LG Blu ray drives. I am running the current Mint Cinnamon distro. I have installed the current version of MakeMKV Linux 1.18.3. It recognizes when I load the disc, but never gets past the "loading disc" part. I have tried both the official install via compiling from source and the Flatpack version from Flathub, both have the same problem. It happens with DVDs and regular Blurays. I have not cross flashed the Drive or enabled LibreDrive yet. As I am just doing DVDs and regular Blurays now. Not 4K yet. Below are drive specs from MakeMKV. Can someone please advise me on what to do?
Drive Information:
Product: BD-RE BU40N
Revision: 1.05
Firmware Date: 2121-04-23 13:47
Bus Encryption flags: 17
Drive Platform: MT1959
Newbie here. MakeMKV stuck loading disc on Linux
Setta
3JplMQv9
Re: Newbie here. MakeMKV stuck loading disc on Linux
Same Problem here, flatpak or from 3rd party repo (packman opensuse). That seems to be a bug in all versions.
Found a workaround in the Linux Mint forum:
Start Makemkv
Have another internal or external USB CD-Drive and insert a normal DVD. MakeMKV should load the DVD and offer copying the files. Now insert a BR disk in the BR-Drive. MakeMKV now should read the BR disc and offers the BR Disc via drop down menue.
Hope it works for you
And hopefully it will be fixed, because it looks like that bug wasn't there forever and only started to appear mid/end of last year.
Start Makemkv
On linux, the BU40N works a lot better on the 1.00 firmware.Setta wrote: Fri Jan 30, 2026 3:13 am Hello. I am brand new to MakeMKV. I just got one of the recommend LG Blu ray drives. I am running the current Mint Cinnamon distro. I have installed the current version of MakeMKV Linux 1.18.3. It recognizes when I load the disc, but never gets past the "loading disc" part. I have tried both the official install via compiling from source and the Flatpack version from Flathub, both have the same problem. It happens with DVDs and regular Blurays. I have not cross flashed the Drive or enabled LibreDrive yet. As I am just doing DVDs and regular Blurays now. Not 4K yet. Below are drive specs from MakeMKV. Can someone please advise me on what to do?
Drive Information:
Revision: 1.05
SamSpeexy
Linux versions after 1.17.7 don't work well unless your drive has libredrive firmware. ( LINK )Setta wrote: Fri Jan 30, 2026 3:13 am LibreDrive Information
Check out the Ultimate UHD Drives Flashing Guide to learn how to flash your drive to libredrive firmware. ( LINK )
Setta
Thanks for the idea. I will give this a try. I believe I have another dvd drive laying here somewhere.3JplMQv9 wrote: Fri Jan 30, 2026 9:05 am Same Problem here, flatpak or from 3rd party repo (packman opensuse). That seems to be a bug in all versions.
Start Makemkv
Setta
Thanks for the info. I also just recently saw something about older firmwares being better. I will look into this.dcoke22 wrote: Fri Jan 30, 2026 2:55 pmOn linux, the BU40N works a lot better on the 1.00 firmware.Setta wrote: Fri Jan 30, 2026 3:13 am Hello. I am brand new to MakeMKV. I just got one of the recommend LG Blu ray drives. I am running the current Mint Cinnamon distro. I have installed the current version of MakeMKV Linux 1.18.3. It recognizes when I load the disc, but never gets past the "loading disc" part. I have tried both the official install via compiling from source and the Flatpack version from Flathub, both have the same problem. It happens with DVDs and regular Blurays. I have not cross flashed the Drive or enabled LibreDrive yet. As I am just doing DVDs and regular Blurays now. Not 4K yet. Below are drive specs from MakeMKV. Can someone please advise me on what to do?
Drive Information:
Revision: 1.05
Setta
Thank you for the links and info about the MakeMKV version. I do plan on getting LibreDrive setup on it as I will need 4K ripping at some point.SamSpeexy wrote: Fri Jan 30, 2026 7:19 pmLinux versions after 1.17.7 don't work well unless your drive has libredrive firmware. ( LINK )Setta wrote: Fri Jan 30, 2026 3:13 am LibreDrive Information
