Can anyone help me, have this System:
can I RIP UHD motion pictures to MKV's
Nowhere is it written that (I can't find)
Pioneer Bdr-211EBK
Asus ROG Strix B450-F Gaming Mainboard Sockel AM4
AMD YD2600BBAFBOX Prozessor RYZEN5 2600 Socket AM4 3.9Ghz
Gigabyte GeForce GTX 1050 Ti G1
Sorry my English is not so good.
PIONEER BDR 211 EBK
BlueMac77
- Contact:
Re: PIONEER BDR 211 EBK
Hi Robert1972. Sorry the Pioneer BDR-211 -EBK cannot rip 4K UHDs using MakeMKV. This drive can only rip 1080p Blu-Rays Get the Asus or LG optical drives listed here https://www.makemkv.com/forum/viewtopic ... 16&t=19634Robert1972 wrote: Sun Jul 28, 2019 5:25 pm Can anyone help me, have this System:
Pioneer Bdr-211EBK
Robert1972
Thank you for the Information.
I heard that AMD can't work with UHD-drives.
What do i need for streaming UHD's, only a UHD-drive from the List ??
lfcarreon1
I bought the same drive way back in August 2019 but was unable to install it until today (27 October 2019) because I was looking after some visitors. Now that I'm free, I replaced my BDR209 with the BDR211. I was not aware that there are recommended UHD drives to use with MakeMKV. I was very disappointed to discover after installing that the drive is unable to rip UHD disks. Is there no other way to make this work apart from replacing the UHD drive?
Nope. Pioneer drives are not UHD friendly at all and currently can't be flashed to make them friendly.lfcarreon1 wrote: Sun Oct 27, 2019 9:05 am I bought the same drive way back in August 2019 but was unable to install it until today (27 October 2019) because I was looking after some visitors. Now that I'm free, I replaced my BDR209 with the BDR211. I was not aware that there are recommended UHD drives to use with MakeMKV. I was very disappointed to discover after installing that the drive is unable to rip UHD disks. Is there no other way to make this work apart from replacing the UHD drive?
FernyInferno
Is there any update on this drive for flashing to 4k?
It works fine with MakeMKV for regular bluray but ive seen much much older drives like the pioneer BDR-UD03FAL from 2013 is possible to flash for 4k...im confused what makes this one unflashable ?
I hoped this could be cross flashed to the pioneer bdr-211UBK?? Or any other solution now at 2026?
yes if you have fw before 12/22 just email me your drive info section and i can send you an auto flasherFernyInferno wrote: Fri Jan 30, 2026 4:04 am Is there any update on this drive for flashing to 4k?
see email below
