How Do I Play Region B Blu-Ray Directly From Disc?
zoom+slomo
Post by zoom+slomo » Wed Jan 21, 2026 4:32 am
https://www.blu-ray.com/movies/The-Sorc ... ay/360726/
Unfortunately for me, this very good a/v quality edition of an old favorite is Region B locked, so my Oppo 203 players won't read it. But after installing MakeMKV neither will VLC player.
Here's what MakeMKV says about everything:
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: KLNK5UA2029
Highest AACS version: 76
Firmware version: 1.05
Disc Information
Label: THE SORCERERS
Timestamp: 2024-06-30 17:35:19
Protection: AACS v68
Data capacity: 32.18 Gb
Disc type: BD-ROM
Number of layers: 2
Please describe what changes to make for playing the movie directly from disc.
Re: How Do I Play Region B Blu-Ray Directly From Disc?
Post by MartyMcNuts » Thu Jan 22, 2026 12:19 am
zoom+slomo wrote: Wed Jan 21, 2026 4:32 am https://www.blu-ray.com/movies/The-Sorc ... ay/360726/
Revision: 1.05
Disc Information
Disc type: BD-ROM
Number of layers: 2
Don't play the disc, rip it. Your LG drive will thank you! Then you can watch the ripped file on your oppo or on your PC.
If you must play it (not recommended), integrate VLC with MakeMKV in preferences so it can be used as the on-the-fly derypter.
zoom+slomo
Post by zoom+slomo » Thu Jan 22, 2026 5:07 pm
MartyMcNuts wrote: Thu Jan 22, 2026 12:19 am Don't play the disc, rip it. Your LG drive will thank you! Then you can watch the ripped file on your oppo or on your PC.
Thanks for your reply. But if I do rip it I would want to copy the entire disc, including all the extras, like all of the commentaries. And I will I also retain complete BD menu functionality?
To do this do I rip the entire disc in one session and save it as an ISO or some other file format?
If yes, I've never done this. How to do that or do what else for what I want?
Also, I don't have a server; hopefully, later this year. But one reason why I don't like doing DVD-much less BD-ripping is that my PC's system and storage drives are SSDs, and unlike HDDs you permanently lose free space even if you later "delete" any content.
When I do get my ~ 12 TB server most of its drives will likely be SSDs. But I do have a 4TB external HDD.
https://www.seagate.com/products/extern ... TKP6000400
Can makeMKV rip the entire BD movie disc, save it as an ISO or MKV (which ??) file and store it directly to my external drive, without needing to first store any of it to my internal SSDs?
Please describe all steps to do this.
Post by dcoke22 » Thu Jan 22, 2026 7:03 pm
Haven't you had this conversation before? What software to fully read UHD Blu-ray?
I don't think anything has changed since then.
Post by dcoke22 » Thu Jan 22, 2026 7:15 pm
zoom+slomo wrote: Thu Jan 22, 2026 5:07 pm Also, I don't have a server; hopefully, later this year. But one reason why I don't like doing DVD-much less BD-ripping is that my PC's system and storage drives are SSDs, and unlike HDDs you permanently lose free space even if you later "delete" any content.
Modern operating systems use the TRIM command with SSDs. I would not characterize storing a file on a SSD and then later deleting it as permanently losing free space.
zoom+slomo wrote: Thu Jan 22, 2026 5:07 pm When I do get my ~ 12 TB server most of its drives will likely be SSDs. But I do have a 4TB external HDD.
If the main thing I was going to store on a NAS is movies, I wouldn't make the primary storage medium of the NAS be SSDs. SSDs are generally more expensive per TB than HDDs and the various speed advantages of SSDs are wasted when accessing movies. There are other usage scenarios where SSD storage in a NAS makes sense.
zoom+slomo
Post by zoom+slomo » Thu Jan 22, 2026 8:43 pm
dcoke22 wrote: Thu Jan 22, 2026 7:15 pm Modern operating systems use the TRIM command with SSDs. I would not characterize storing a file on a SSD and then later deleting it as permanently losing free space.
I don't agree with your first statement as TRIM command or not any space written to an SSD can be done so only once, unlike an HDD. Of course, both drive technologies have their pros and cons.
What stinks is that I just found out here https://www.avsforum.com/threads/offici ... /page-2261 that even if makeMKV can rip and save an entire BD movie to an ISO file my Oppo BD player can't play ISO files without installing Jailbreak firmware, which I really don't want to risk installing.
So, instead since I want to rip the BD's entire contents what are the steps to do so?
And then do I end up with having a folder of sub folders on the HDD that I access via the Oppo's remote? Have you ever done this with an Oppo, Panasonic, Sony or other BD player's remote?
Post by dcoke22 » Thu Jan 22, 2026 10:01 pm
zoom+slomo wrote: Thu Jan 22, 2026 8:43 pm So, instead since I want to rip the BD's entire contents what are the steps to do so?
On the first screen of MakeMKV, there's an icon of a yellow folder with a green arrow. This will allow you to make an optionally decrypted backup of a disc. In the case of a DVD, MakeMKV will produce an .iso file. In the case of a blu-ray or UHD, it'll produce a folder with the entire disc's contents.
I have no idea if any of your disc players can play a backup. I've seen some folks on the forum talk about using a Dune player to play backups, but I don't have any experience with any playback system using backups.
zoom+slomo
Post by zoom+slomo » Thu Jan 22, 2026 10:31 pm
Well, I believe the manual says that my Oppo 203 can play MKV files, so I guess as long as those folders are shown on the player's OSD then I can probably access them.
Post by MartyMcNuts » Thu Jan 22, 2026 10:36 pm
zoom+slomo wrote: Thu Jan 22, 2026 10:31 pm Well, I believe the manual says that my Oppo 203 can play MKV files, so I guess as long as those folders are shown on the player's OSD then I can probably access them.
If you rip the whole disc to a folder backup, they won't be MKV files. They will be the exact same files (and file structure) that's on the disc, just decrypted.
zoom+slomo
Post by zoom+slomo » Thu Jan 22, 2026 10:50 pm
MartyMcNuts wrote: Thu Jan 22, 2026 10:36 pm If you rip the whole disc to a folder backup, they won't be MKV files. They will be the exact same files (and file structure) that's on the disc, just decrypted.
But isn't an ISO file? If yes, I just learned here that my Oppo player won't play ISO files, at least not without that Jailbreak firmware.
https://www.avsforum.com/posts/64431563/
So then what are the steps to rip the disc to what kind of folders so that the Oppo can access the main movie and the extras?
Post by MartyMcNuts » Thu Jan 22, 2026 11:19 pm
zoom+slomo wrote: Thu Jan 22, 2026 10:50 pm
No, MakeMKV can rip a complete DVD to ISO but it only rips a complete blu-ray / UHD disc to a folder backup. This folder backup is exactly the same file structure and file types as what is on the disc, just decrypted.
I have no idea what an Oppo can play. You would have to read your manual or do some research on Oppo file compatibility.
bl4ck
Post by bl4ck » Thu Jan 29, 2026 6:27 pm
Oppo 93 95 - can play BDMV structures on factory firmware (ISO support was removed in newer versions; there is a jailbreak that restores ISO support and also adds region changing and disables UOP/PUO for Blu-ray and DVD).
Oppo 103 105 - can play BDMV, but only after using bdmv_modifier. If we want to play over the network, it additionally requires the AVCHD folder (with jailbreak it can open structures without bdmv_modifier as well as ISO).
Oppo 203 305 - can play BDMV, but only after using bdmv_modifier. If we want to play over the network, it additionally requires the AVCHD folder (with jailbreak it can open structures without bdmv_modifier as well as ISO).
