Hi, Need help, please.
I think I’ve made a mistake flashing the below Asus SBW-06D2X-U. I flashed with SDFtool Flasher and MK firmware, ‘HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936’. It said it was successful but now the drive just has a flashing green light. Won’t open or read anything. My PC still recognises it. It shows up in explorer and MakeMKV. Shows driver details below. The drive just won’t eject or read. Just flashes green. I think; I’ve either flashed it with the wrong firmware, or, the wrong flasher? OR, both! Because the drive is still recognised. I hope this is fixable? Does anyone know what I should flash it with, and with what flasher, to fix it? It's a slimline Asus drive. I think another forum poster had the same problem, 'Maffo999', on page 21. Hope there was a solution?
Before I flashed it:
OS device name: E:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: A102
Serial number: [redacted]
Firmware date: 2121-06-28 13:41
Bus encryption flags: 1F
Highest AACS version: 82
After I flashed it:
OS device name: E:
Product: BD-RE WH16NS6
Revision: 1.02
Serial number: MODMCEF3236
Firmware version: 1.02
ASUS SBW-06D2X-U
Re: ASUS SBW-06D2X-U
It's a slim drive but you flashed it with internal desktop drive firmware. The one thing that the UHD drive flashing guide says not to do!!deano125 wrote: Wed Jan 28, 2026 5:48 pm Hi, Need help, please.
OS device name: E:
Manufacturer: ASUS
Revision: A102
After I flashed it:
OS device name: E:
Revision: 1.02
Use the RECOVER method of SDFtool flasher, selecting the drive's current firmware in the popup window then choose BU40N 1.03-MK in the normal firmware selection drop down box.
asamaseymasa
Hi, can someone help me flash my drive? Thank you in advance.
OS device name: E:
Manufacturer: ASUS
Revision: A102
Serial number: MO5O68E3544
Highest AACS version: 76
OS device name: E:
Manufacturer: ASUS
Revision: A102
See guide belowasamaseymasa wrote: Fri Jan 30, 2026 1:01 pm Hi, can someone help me flash my drive? Thank you in advance.
OS device name: E:
Manufacturer: ASUS
Revision: A102
Treat it as bu40n
Or email me or Marty for an automated flasher
deano125
Thanks, fixed!MartyMcNuts wrote: Wed Jan 28, 2026 11:56 pmIt's a slim drive but you flashed it with internal desktop drive firmware. The one thing that the UHD drive flashing guide says not to do!!deano125 wrote: Wed Jan 28, 2026 5:48 pm Hi, Need help, please.
OS device name: E:
Manufacturer: ASUS
Revision: A102
After I flashed it:
OS device name: E:
Revision: 1.02
Madball
Is my drive flashable? I'm quite new to all this, have dvdfab and makemkv. Today I also found taht my drive wouldn't read certain blu ray discs or would give errors halfway through reading. Any ideas on causes? The discs were commercial either region ABC or B. I'm in the UK.
OS device name: H:
Current profile: BD-R SRM
Manufacturer: ASUS
Revision: A102
Serial number: MO8O68G5851
Highest AACS version: 68
OS device name: H:
Manufacturer: ASUS
Revision: A102
Yeah, it can be flashed. It's a LG drive inside so flash it to BU40N 1.03-MK first, then flash it to BU40N 1.00 to use it with DVDFab.Madball wrote: Tue Feb 03, 2026 9:21 pm Is my drive flashable? I'm quite new to all this, have dvdfab and makemkv. Today I also found taht my drive wouldn't read certain blu ray discs or would give errors halfway through reading. Any ideas on causes? The discs were commercial either region ABC or B. I'm in the UK.
OS device name: H:
Manufacturer: ASUS
Revision: A102
Without you pasting the log window, we dont know the exact errors you are getting but... Clean the disc, even if it look good. 99% of the time this resolves general read errors.
Also ensure the drive is getting enough constant power. Don't use case ports. Use a port direct from the motherboard or an AC self-powered USB hub of at least 24w.
Madball
Well....I'm absolutely gobsmacked! I gave the seemingly clean discs a good rub with a microfibre cloth and now all ripped ok!MartyMcNuts wrote: Wed Feb 04, 2026 12:31 amYeah, it can be flashed. It's a LG drive inside so flash it to BU40N 1.03-MK first, then flash it to BU40N 1.00 to use it with DVDFab.Madball wrote: Tue Feb 03, 2026 9:21 pm Is my drive flashable? I'm quite new to all this, have dvdfab and makemkv. Today I also found taht my drive wouldn't read certain blu ray discs or would give errors halfway through reading. Any ideas on causes? The discs were commercial either region ABC or B. I'm in the UK.
OS device name: H:
Manufacturer: ASUS
Revision: A102
Now, to get my head round how to flash a drive....
Try the SDFtool Flasher thread.Madball wrote: Wed Feb 04, 2026 6:59 pmWell....I'm absolutely gobsmacked! I gave the seemingly clean discs a good rub with a microfibre cloth and now all ripped ok!MartyMcNuts wrote: Wed Feb 04, 2026 12:31 amYeah, it can be flashed. It's a LG drive inside so flash it to BU40N 1.03-MK first, then flash it to BU40N 1.00 to use it with DVDFab.Madball wrote: Tue Feb 03, 2026 9:21 pm Is my drive flashable? I'm quite new to all this, have dvdfab and makemkv. Today I also found taht my drive wouldn't read certain blu ray discs or would give errors halfway through reading. Any ideas on causes? The discs were commercial either region ABC or B. I'm in the UK.
OS device name: H:
Manufacturer: ASUS
Revision: A102
scoop
Hello, I bought a drive and would like to unlock it to read UHD discs. Is it possible ?
OS device name: E:
Manufacturer: ASUS
Revision: A102
Serial number:
sorry, it's out of date. I first uploaded FW BU40N 1.03 MK and then 1.0 but DVDFAB 13 didn't want to accept the drive. I had to download FW 1.00 from UHD drive tool. Now everything works.
OS device name: E:
Manufacturer: ASUS
Revision: A102
Serial number:
jimborob
I've had this drive for a while and would now like to make it UHD compatible. Is it possible? Thanks in advance.
OS device name: /dev/rdisk4
Manufacturer: ASUS
Product: SBC-06D2X-U
Revision: 1.10
Serial number: TFDL176913WL
Firmware date: 2017-04-18
Highest AACS version: 66
Drive platform: RS8591
Firmware version: 1.10/ID22
Manufacturer: ASUS
Revision: 1.10
I'm not sure if those combo drives can be flashed. Maybe Coopervid or Billycar11 can chime in here.jimborob wrote: Thu Feb 19, 2026 11:05 pm I've had this drive for a while and would now like to make it UHD compatible. Is it possible? Thanks in advance.
Manufacturer: ASUS
Revision: 1.10
boguslecina
I recently asked Coopervid and platform 8591 is a combo and can't be flashed.
zittrig
As far as I know, Pioneer Combo drive can't be flashed, only the combos from / with LG inside (LG CH12NS40, ASUS BC-12D2HT with MT1959 and BC-12B1ST with MT1959).
All ASUS SB"C"-Drives can't be flashed. Only SB"W" with a flashable drive inside.
Correct. Unfortunately.boguslecina wrote: Fri Feb 20, 2026 7:52 am I recently asked Coopervid and platform 8591 is a combo and can't be flashed.
