#3526 Post by MartyMcNuts » Tue Jan 27, 2026 3:40 am
austincummings0324 wrote:
Tue Jan 27, 2026 2:31 am
MartyMcNuts wrote:
Mon Jan 26, 2026 9:55 am
Mon Jan 26, 2026 6:34 am
I assume the following is what you mean for the NB52.
NB52 to > BP50NB40-NB50-1.03MK with enc > BP50NB40-NB50-1.03MK with bootloader/full flash > BP60NB10 1.00_HBD from Marty download/file.php?id=2143
I personally am reading this as 3 steps but I don't want to flash it wrong. Is the bootloader an extra file I have to flash or can I go straight from 1.03 to cross flashing to BP60? Maybe I can understand it better in the thread. Can you link to it for me please?
No, that is not what I mean. I said the first post of the SDFtool Flasher thread.
Hi Marty,
I found the thread and followed the gif but now I'm getting a error where my drive says no disc when I have a disk in it. Do you know how to fix that?
Paste the MakeMKV drive info and libredrive info sections so I can see if it flashed correctly. If it still says BP50NB40 then you haven't flash it correctly.
austincummings0324
#3527 Post by austincummings0324 » Tue Jan 27, 2026 3:53 am
Hi Marty,
Here is the drive info as I flashed it.
OS device name: F:
Product: BD-RE BU40N
Revision: 1.00
Serial number: SIK0FPB2B2059
Firmware date: 2116-12-20 15:28
Firmware version: 1.00
#3528 Post by MartyMcNuts » Tue Jan 27, 2026 6:11 am
Hi Marty,
OS device name: F:
Revision: 1.00
Ok, all good.
1. Ensure you insert the disc first, let the OS initialise it before you open up MakeMKV.
2. Ensure the drive is getting enough power. Don't use case ports as these often don't provide enough constant power for optical drives. Use ports direct from the motherboard or an AC self-powered USB hub of at least 24w. USB-C is even better if you can. If using the y-cable that came with the drive, make sure both USB connections are plugged in.
austincummings0324
#3529 Post by austincummings0324 » Tue Jan 27, 2026 1:25 pm
OS device name: F:
Revision: 1.00
Ok, all good.
Right now I have the Y-cable plugged into both ports on my mother board. My computer can't even register it in Files explorer even though makemkv can. I have tried to power cycle my computer and drive as well. It appears the cable is on and giving power but should I try it with a USB-C to MicroUSB cable instead just to see if that would be better?
TechSmid
#3530 Post by TechSmid » Tue Jan 27, 2026 6:09 pm
Good evening,
I'm trying to figure out how to flash my Verbatim.
I've looked at all the descriptions and videos, but I don't understand which flasher I should use.
This is my drive info:
Revision: 1.05
Serial number: ****
Highest AACS version: 82
Kind regards,
Rick
Fave119
#3531 Post by Fave119 » Tue Jan 27, 2026 8:34 pm
Good evening,
Revision: 1.05
Serial number: ****
Kind regards,
Rick
I think I have the exact same drive as you, also a Verbatim with the exact same drive information.
I found this repo which worked for me: https://github.com/nxyzo/Flashing-Verba ... -to-1.03MK
I am now on Revision 1.03 with fully enabled libredrive :)
AnimatedConverse
#3532 Post by AnimatedConverse » Tue Jan 27, 2026 9:31 pm
I can see that it's possible to use this to flash my drive, but will it work just to pick the DE_ASUS_BW-16D1HT_3.10_MK.bin or DE_ASUS_BW-16D1HT_3.02.bin firmware? My drive is the BW-16DH-U
My drive looks like this in makemkv:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: A205
Serial number: KLQN61H0044
Firmware date: 2120-12-01 18:18
Bus encryption flags: 1F
Thanks so much!
#3533 Post by MartyMcNuts » Tue Jan 27, 2026 10:00 pm
OS device name: F:
Revision: 1.00
Ok, all good.
Sure, it's worth a try. USB-C is the better option when available.
#3534 Post by MartyMcNuts » Tue Jan 27, 2026 10:02 pm
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: A205
Thanks so much!
Yes, 3.10-MK can be flashed to directly. If you want to use 3.02, you can flash to it afterwards.
mannduro
#3535 Post by mannduro » Tue Jan 27, 2026 10:23 pm
hi, this is my Drive (external USB 3.0 Drive)
Laufwerksinformation
OS-Gerätename: E:
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: A101
Serienummer: K92F3JC0726
Firmware-Datum: 2114-12-08 09:59
Markierungen der Bus-Verschlüsselung: 1F
Highest AACS version: 68
Drive platform: MT1939
Firmware version: 0.A101W
BD raw metadata read: Partial
How do i make this read UHD discs ?
#3536 Post by Billycar11 » Tue Jan 27, 2026 11:56 pm
OS-Gerätename: E:
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: A101
You don't it's 12+ years old
Don't flash it. It will die
austincummings0324
#3537 Post by austincummings0324 » Wed Jan 28, 2026 1:16 am
Ok, all good.
I tried to use a USB-C to MicroUSB cable direct to my motherboard and it still didn't work. Even tried using a dock and it didn't work. Any idea why a brand new drive would do this after being flashed? Starting to feel like I should return the drive and try again... :( :(
#3538 Post by MartyMcNuts » Wed Jan 28, 2026 1:39 am
Nope, no idea. Did you test the drive with a blu-ray before flashing just to make sure the drive worked and wasn't faulty to begin with?
If you are going to return it, you can do the RECOVER process again, this time, selecting the current BU40N firmware that is on the drive, then choose the BP50NB10 1.03-MK firmware in the normal firmware selection drop down box.
austincummings0324
#3539 Post by austincummings0324 » Wed Jan 28, 2026 3:20 am
I ended up returning the drive. I think this one was a bit complicated for me. Do you have any recommendations on drives below $200 USD? I don't really have the budget to buy one alr flashed so I will have to deal with one I need to flash on my own. I was looking at getting the BP60NB10 or an actual BU40 instead. Thoughts?
#3540 Post by MartyMcNuts » Wed Jan 28, 2026 4:10 am
Verbatim 43887 (normally a Pioneer BDR-UD03), 43888 (contains a LG BU40N), 43889 (contains a LG BU40N) or 43890 (can be either a Pioneer BDR-UD03 or a LG BU40N).
