No optical drives found
El Schnittlauch
Post by El Schnittlauch »
I have been using MakeMKV a lot lately. After I updated it to MakeMKV v 1.13.3 win(x64-release) just a few minutes ago, it now just wont work: "The program could not find any usable optical drives". It says that although I've been working with my drive and MakeMKV all day just fine. I am gratefull for all suggestions, how to fix it.
Re: No optical drives found
El Schnittlauch wrote:
Mon Jan 26, 2026 2:54 pm
Try power cycling the drive or power off the PC for a few minutes if the drive is installed internally.
I haven't seen the need to update MakeMKV as yet. I'm still using v1.17.6.
El Schnittlauch
Thank you very much for the informtaion, it worked :)
