Allegiant
mr.ripper
Re: Allegiant
With help of AnyDVD, VLC and Process Explorer, it looks like 00230.mpls is the correct one, but haven't watched and confirmed yet.
kimkadn
Re: Allegiant
The Nordic version of Allegiant has this corerct playlist:
Title information
Source file name: 00230.mpls
Duration: 2:00:23
Chapters count: 12
Segment count: 15
Segment map: 102,111,110,106,109,113,114,112,104,105,20,101,108,107,115
File name: title_t65.mkv
Title information
Duration: 2:00:23
Chapters count: 12
Segment count: 15
powrhaus
Re: Allegiant
Just inserted my new copy of Allegiant I got from BestBuy in the US. I have Java installed and MakeMKV did not select the correct title. All titles were selected (there were about 300). Luckily I found this thread and was able to hopefully select the correct title. Unfortunately for some of the other movies I ripped, I simply guessed on which one was correct and will now have to figure out which movies they were so I can re-rip them.
I thought the whole point of installing Java JRE (which I did today) was to have MakeMKV figure out the correct title. Is that not the case? If it doesn't, then what does having Java installed do?
rifth427
Re: Allegiant
I bought the three movies together in one package off amazon. (Insurgent allegiant and divergent). I am no where near figuring out which one the correct title is... as mine is not numbered the same as this posts.
For instance, my first selection looks like this
Title information
Source file name: 00010.mpls
Duration: 2:00:33
Chapters count: 16
Segment count: 20
Segment map: 513,501,520,517,511,512,503,519,502,516,510,506,515,509,508,518,505,514,504,507
File name: Allegiant_t00.mkv
and there are about 300 to choose from. Where do I start, I mean I started going through all the segment maps but EVERY one of them starts with 513. So it does not appear to match anything listed in this thread. I cannot take the time to watch every segment and match it up - sorry not gonna happen.
Title information
Duration: 2:00:33
Chapters count: 16
Segment count: 20
thetoad
Re: Allegiant
I once wrote a script (might be somewhere here) that would have makemkv enumerate all the playlists and then sort them in segment order.
one could then easily do a search to see which segments make sense following the previous one. As they are sorted, when one hits one that doesn't make sense, one can make a big jump to the next egment to try until one finds the segment that makes sense. rinse and repeat and you will end up with the correct playlist.
Re: Allegiant
viewtopic.php?p=99088#p99088thetoad wrote: Tue Nov 02, 2021 3:06 pm I once wrote a script (might be somewhere here) that would have makemkv enumerate all the playlists and then sort them in segment order.
I think that's the post you're talking about.
Balefire
Re: Allegiant
This was the same segment map as I had on my copy of Allegiant from a 3-disc set bought off Amazon in 2022, though for me it was title 253.Axehandler wrote: Tue Jul 12, 2016 5:41 pm Title information
Source file name: 00838.mpls
Duration: 2:00:33
Chapters count: 16
Segment count: 20
Segment map: 513,520,501,517,511,519,512,503,502,516,510,506,518,504,515,514,508,505,509,507
File name: Allegiant_t254.mkv
SquishyMan
Re: Allegiant
I have the 3 disc pack from Amazon too (purchased this year). I found the same video with the same segment map, however it was title 25 for me.
Re: Allegiant
Title count will vary depending on Preferences > Video tab > 'Minimum title length (seconds)' value.
Annihilation
Re: Allegiant
509, 511, 515, 501, 510, 503, 513, 502, 508, 504, 505, 507, 506, 512, 514 worked for me. I had to back up an encrypted copy first because stream 502 would fail otherwise.
EbonHawk
Re: Allegiant
Can confirm that 838 mpls is the correct one for a 3-pack Divergent Series blu-ray I found at a thrift store in the US.
I just looked for the complete numbering shown above (509, 511, 515, 501, 510, 503, 513, 502, 508, 504, 505, 507, 506, 512, 514) and luckily, when I tried all the numbers listed in this thread for the given .mpls files, it was the 838. Otherwise, don't think I ever would have found it. Thanks for the info, guys! thank goodness people are willing to do this for others.
razthal
Re: Allegiant
I found this seq pattern in 00509.m2ts t280 - not sure which version of the disc I have as my wife bought it years ago.
