LG BU40N SDFtool Flasher v1.3.6. "Command produced error code 0xff056103"
dialogueravenous
Post by dialogueravenous »
I'm trying to flash an LG BU40N using SDFtool Flasher v1.3.6 on Windows 10 using firmware file HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin but when I click "start" I get the error "Command produced error code 0xff056103"
Is there something I'm doing wrong here? I have makemkv latest version installed on windows 10.
Drive details from makemkv v1.18.2 on macos:
OS device name: /dev/rdisk6
Current profile: CD-ROM
Product: BD-RE BU40N
Revision: FR07
Firmware date: 2116-12-20 16:51
Bus encryption flags: 1F
Highest AACS version: 76
Firmware version: 0.FR07J
Disc Information
Label: DX-ESATL
Timestamp: 2009-04-28 15:23:14
Data capacity: 0.4 Gb
Re: LG BU40N SDFtool Flasher v1.3.6. "Command produced error code 0xff056103"
dialogueravenous wrote: Sun Jan 25, 2026 6:13 am I'm trying to flash an LG BU40N using SDFtool Flasher v1.3.6 on Windows 10 using firmware file HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin but when I click "start" I get the error "Command produced error code 0xff056103"
Revision: FR07
Serial number:
Disc Information
Label: DX-ESATL
Take the disc out of the drive.
I also recommend flashing directly to DE_LG_BU40N_1.00 for your drive as your firmware is not encrypted.
dialogueravenous
MartyMcNuts wrote: Sun Jan 25, 2026 6:16 am
Revision: FR07
Serial number:
Disc Information
Label: DX-ESATL
Oh $h!t, thank you! I flashed it to HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin, if I want to flash to DE_LG_BU40N_1.00 can I do that without going back to the original firmware? DE_LG_BU40N_1.00 wasn't in "The all you need firmware pack". Do you know where I get that from a reputable source?
dialogueravenous wrote: Sun Jan 25, 2026 7:19 am
Revision: FR07
Serial number:
Disc Information
Label: DX-ESATL
It is in my all you need firmware pack in the same location/post that you downloaded SDFtool flasher from.
dialogueravenous
MartyMcNuts wrote: Sun Jan 25, 2026 7:50 am
Ah, I see, I was using the all you need firmware pack BillyCar11 posted in this guide which seems to be a different pack: viewtopic.php?f=16&t=19634
dialogueravenous wrote: Mon Jan 26, 2026 5:27 am
I haven't looked but would be suprised if his firmware pack doesn't include it.
