Sure just email me that drive info section see below for emailnthdgreee wrote: Sun Jan 25, 2026 7:48 pm
I'm interested in the firmware to enable UHD support on my drive. I would appreciate the help. Thank you.
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.01
Serial number: (Redacted)
Firmware date: 2021-07-20
Bus encryption flags: 13
Highest AACS version: 50
Drive platform: RS8F00
Firmware version: 1.01/ID06
BDR 212V UHD Guide
Re: BDR 212V UHD Guide
idajava
Good evening, Coopervid.
I want to flash my BDR-212V for UHD. Below is the drive info. Thanks!
OS device name: F:
Revision: 1.02
Serial number: DCDL025716WL
Firmware date: 2022-05-31
Highest AACS version: 63
Firmware version: ID06
OS device name: F:
Revision: 1.02
PM sent.idajava wrote: Mon Feb 02, 2026 5:22 am Good evening, Coopervid.
OS device name: F:
Revision: 1.02
r.j.macreedy
Hi Cooper. Wanting to flash this:
Revision: 1.02
Serial number: DGDL027863WL
Highest AACS version: 82
Revision: 1.02
PM sent.r.j.macreedy wrote: Tue Feb 03, 2026 9:29 pm Hi Cooper. Wanting to flash this:
Revision: 1.02
Rays1
Yep thanks Billy. I really appreciate you getting me sorted when I began all of this.Billycar11 wrote: Sun Jan 18, 2026 11:33 pmPretty sure I helped you out in the email already correct?Rays1 wrote: Sat Jan 17, 2026 10:32 pm Good day gents, I've got the same drive recently and Billy sent me the auto flasher. I've got a couple of questions.
Does this drive look like it was flashed already? Is this something you can't tell from looking at the data. I know it just spins up then stops and ejects. Also @billycar11 sent me the auto flasher but I can't get past the part where it says configuration files missing. I suspect that isn't part of what Billy sent me as they must be available here in the database of flash tools and I'm supposed to pull the 3.10 file from there drag and drop??? I don't get it. Please go easy on me I'm not that savvy when it comes to this particular task.
And your all flashed now
no problem any one else who needs a flash feel free to email me see below for my emailRays1 wrote: Wed Feb 18, 2026 1:05 pm
axlepin
Hi Cooper, would like to flash this drive, details below:
Revision: 1.02
Serial number: DDDL026627WL
Revision: 1.02
PM sent.axlepin wrote: Mon Mar 02, 2026 3:28 am Hi Cooper, would like to flash this drive, details below:
Revision: 1.02
axlepin
Coop, you the man. Thanks.
Boonjii
Hey Cooper,
I'd like to flash my drive. Details:
OS device name: F:
Revision: 1.02
Serial number:
Firmware version: ID06-
OS device name: F:
Revision: 1.02
Serial number:
PM sent.Boonjii wrote: Tue Mar 10, 2026 2:21 am Hey Cooper,
OS device name: F:
Revision: 1.02
Serial number:
Boonjii
I appreciate it! Thanks a bunch
alfred60ski
Hi Coopervid , I'm a new user and I can't sent PMs yet. I have a BDR-212V with firmware 1.02 I need 1.01 firmware pack to LibreDrive. Could you please help me out.
PM sent. Enables Libredrive and UHD ripping.alfred60ski wrote: Sat Mar 14, 2026 1:01 pm Hi Coopervid , I'm a new user and I can't sent PMs yet. I have a BDR-212V with firmware 1.02 I need 1.01 firmware pack to LibreDrive. Could you please help me out.
