ASUS BW-16D1X-U - Flashable?
moc514
Re: ASUS BW-16D1X-U - Flashable?
Post by moc514 » Sun Jan 25, 2026 10:04 pm
I just bought a drive on amazon... Here is what MakeMKV give me :
OS device name: /dev/sr1
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: KL7P4HJ2039
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
But as soon as I put a BluRay(regular one) in the app freeze (1.18.3 linux Ubuntu 25.10). I see no way to output log additional logs.
It say LibreDrive is possible, so I would really like to get to support it ! I don't need 4k, but I guess it would be good for HD as well.
I just got a bunch of bluray for my favorite old TV show (A bit tired of the DVD quality). I just bought my first bluray drive (Hope to use it to make M-Disk backup as well for my business) ! I didn't except in 2026 to have so much issues to play simple video !
Post by MartyMcNuts » Mon Jan 26, 2026 1:52 am
moc514 wrote: Sun Jan 25, 2026 10:04 pm I just bought a drive on amazon... Here is what MakeMKV give me :
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
It's a LG drive. You can flash it to WH16NS60 1.02-MK which will enable libredrive and UHD compatibility. Also there can be issues with the latest version of MakeMKV on Linux. Best to use an older version. Some use v1.17.7 on Linux.
moc514
Post by moc514 » Thu Jan 29, 2026 3:54 am
MartyMcNuts wrote: Mon Jan 26, 2026 1:52 am It's a LG drive. You can flash it to WH16NS60 1.02-MK which will enable libredrive and UHD compatibility. Also there can be issues with the latest version of MakeMKV on Linux. Best to use an older version. Some use v1.17.7 on Linux.
Work perfectly, flash the firmware and it working perfectly ! No issue ! I had to downgrade to 1.17.7, which also seem to be working just fine ! (a few issue still (It expect a c:\ drive for some output command line)), but it totally usable. Thanks a lot !
baylin63
Post by baylin63 » Fri Jan 30, 2026 1:40 am
I have an ASUS BW-16D1X-U drive. Here is what MakeMKV reports:
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: KL...
Is this drive flashable?
Post by Billycar11 » Fri Jan 30, 2026 4:53 am
baylin63 wrote: Fri Jan 30, 2026 1:40 am I have an ASUS BW-16D1X-U drive. Here is what MakeMKV reports:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: KLZP58D5834
its is flashable see guide below its an lg wh16ns40
or if you have windows get an auto flasher from me or marty
KrossTV
Post by KrossTV » Wed Feb 04, 2026 3:05 am
Assuming, I have the same LG drive as the previous post from baylin?
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: KLCP4ID3555
Highest AACS version: 81
Post by MartyMcNuts » Wed Feb 04, 2026 3:52 am
KrossTV wrote: Wed Feb 04, 2026 3:05 am Assuming, I have the same LG drive as the previous post from baylin?
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Yep
4K_UHD
Post by 4K_UHD » Thu Feb 12, 2026 7:04 pm
I have another ASUS BW-16D1X-U drive. I reviewed the guide, but I noticed there are several recommendations and different file names listed for the same firmware. I would like to use the drive with both MakeMKV and DVDFab 13. Could you please confirm which file I should use and provide the exact full file name?
I really appreciate your help.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
Highest AACS version: 82
Thank you
Post by Coopervid » Thu Feb 12, 2026 7:12 pm
4K_UHD wrote: Thu Feb 12, 2026 7:04 pm Hi,
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
Thank you
LG WH16NS60 1.00 from the OLD directory of Mike's file or from Marty's All you need firmware pack.
4K_UHD
Post by 4K_UHD » Thu Feb 12, 2026 7:21 pm
I found it "DE_LG_WH16NS60_1.00.bin".
Thank you very much for your help.
4K_UHD
Post by 4K_UHD » Thu Feb 12, 2026 7:59 pm
I'm getting this error message "Command produced error Code 0x82052603"
I'm using SDFlasher (V1.3.6) and I tried ASUS_ODD_FW_Changer
Post by Coopervid » Thu Feb 12, 2026 8:04 pm
4K_UHD wrote: Thu Feb 12, 2026 7:59 pm I'm getting this error message "Command produced error Code 0x82052603"
C'mon. Drive not empty or tray open.
4K_UHD
Post by 4K_UHD » Thu Feb 12, 2026 8:07 pm
Nothing in the drive and tray is closed. I also restarted both PC and Drive.
I tried this file "HL-DT-ST-BD-RE_WH16NS60-1.01-NM00100-211711202000.bin" and I'm getting the same error
Post by Coopervid » Thu Feb 12, 2026 8:10 pm
4K_UHD wrote: Thu Feb 12, 2026 8:07 pm Nothing in the drive and tray is closed. I also restarted both PC and Drive.
Flash first to 1.02. Then to 1.00.
4K_UHD
Post by 4K_UHD » Thu Feb 12, 2026 8:20 pm
It worked.
Thanks again for your help
