I sent two dumps to svq@makemkv.com.
Thanks.
Tim
Dump submitted - The Long Walk {US)
anti-plastic
Re: Dump submitted - The Long Walk {US)
any word on this? im try to rip a blu ray and ig its too new...
The message was about submitting a dump for the UHD version, not the BD version. Depending on the message you received from MakeMKV, you may want to submit the dump for your disk separately.any word on this? im try to rip a blu ray and ig its too new...
BD and UHD disks have different keys, and often different versions distributed by different companies will be different, as well. If your version is a BD, there is also they issue that it seems every edition needs a different key.
There is also the "keydb" database maintained by third parties, which can provide keys as well. Instructions for submitting to that are found here.
