Clearing file history
curiousMonkey
It would be nice if MakeMKV followed the lead of other tools and had an option to clear the file history from the directory selection menu. Using regEdit (Windows) is really tedious for something so simple.
flojo
Re: Clearing file history
I know it's not an answer, but you could edit the shortcut command and prepend 'reg delete "HKCU\blah\blah" /f & ' to the path value. Or so I guess you can as I can't test it (you might have to add 'start /w /b').
Ezatoka
Out of curiousity, where do one see this history in the program? For some reason I don't.
