PM sent.dbirnel wrote: Thu Jan 22, 2026 7:41 pm Hi @Coopervid,
I also have one of these drives. Can this be updated to support 4k UHD?
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Serial number: #####
Firmware date: 2014-12-26
Highest AACS version: 82
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
Pioneer BDR-XD05TS 4k compatibility?
Re: Pioneer BDR-XD05TS 4k compatibility?
comadose
OS device name: E:
Revision: 1.20
Serial number: NDDL001132JP
Firmware date: 2013-11-11
Firmware version: 1.20/ID69
Thanks.
OS device name: E:
Revision: 1.20
Thanks.
It took you from September 2025 to now to say that you got the wrong files????? And at the same time you are getting in an argument with Billy? I need to say that this is pathetic and that I don't like your attitude. However, you should be able to PM now. Contact me and I will check options - what I don't usually do.comadose wrote: Fri Jan 23, 2026 9:29 am Hi @Coopervid, you PMed me some details, but for the '07 drive, not the '05 drive. I can't seem to reply to your PM. Would you mind contacting me? Thanks.
comadose
I had some issues. Thanks for being nicer than Billy I guess.
jwwmah
I also have this drive? What's the secret? Thanks
OS device name: /dev/rdisk1
Current profile: DVD-ROM
Revision: 3.01
Serial number: OGDL062772UC
Highest AACS version: 76
Revision: 3.01
Sure email me that drive info section see below for emailjwwmah wrote: Tue Feb 24, 2026 2:48 am I also have this drive? What's the secret? Thanks
Revision: 3.01
For all others there is no need to post your makemkv drive info section publicly just email it to me directly
eroc1990
Piling onto the pile with my own request. Also, is it possible to do so from Linux or will I need access to a Windows OS to do this? (I assume a VM will be sufficient, worst case).
OS device name: /dev/sr0
Revision: 3.01
Serial number: <redacted>
Highest AACS version: 81
PM sent.eroc1990 wrote: Mon Mar 30, 2026 6:30 pm Piling onto the pile with my own request. Also, is it possible to do so from Linux or will I need access to a Windows OS to do this? (I assume a VM will be sufficient, worst case).
Drive Information OS device name: /dev/sr0 Current profile: DVD-ROM Manufacturer: PIONEER Product: BD-RW BDR-XD05 Revision: 3.01 Serial number: <redacted> Firmware date: 2014-12-26 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8231 Firmware name: PIONEER BDR-XD05 Firmware type: Original (unpatched) Firmware version: 3.01/ID34 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
comadose
If I respond there is no fee required. I only ask for a donation which is not mandatory. I only asked in your case because you have such a bad attitude.comadose wrote: Mon Mar 30, 2026 7:49 pmPM sent.eroc1990 wrote: Mon Mar 30, 2026 6:30 pm Piling onto the pile with my own request. Also, is it possible to do so from Linux or will I need access to a Windows OS to do this? (I assume a VM will be sufficient, worst case).
comadose
You object to other people offering help now? Okay, well, you do you I guess. Speaking of bad attitudes...Coopervid wrote: Mon Mar 30, 2026 8:05 pmIf I respond there is no fee required. I only ask for a donation which is not mandatory. I only asked in your case because you have such a bad attitude.
I always provided the flasher without fees until you showed up with your bad attitude. You have a bad personality. And that's it.comadose wrote: Mon Mar 30, 2026 8:17 pmYou object to other people offering help now? Okay, well, you do you I guess. Speaking of bad attitudes...Coopervid wrote: Mon Mar 30, 2026 8:05 pmIf I respond there is no fee required. I only ask for a donation which is not mandatory. I only asked in your case because you have such a bad attitude.![]()
comadose
Oh, that's not what you told me.Coopervid wrote: Mon Mar 30, 2026 8:28 pmI always provided the flasher without fees until you showed up with your bad attitude. You have a bad personality. And that's it.comadose wrote: Mon Mar 30, 2026 8:17 pmYou object to other people offering help now? Okay, well, you do you I guess. Speaking of bad attitudes...Coopervid wrote: Mon Mar 30, 2026 8:05 pmIf I respond there is no fee required. I only ask for a donation which is not mandatory. I only asked in your case because you have such a bad attitude.![]()
"Pick the number of drives and which and send $25 : 20 Euro per drive to redacted@gmail.com with paypal friends and family."
Because of your fucked up attitude you showed. I never asked anyone before for a fixed fee.
comadose
