Billycar11 Selling Flashed Pioneer UHD Drives USA only, Remote Flashing,Tested & Makemkv Discount Code
Re: Billycar11 Selling Flashed Pioneer UHD Drives USA only, Remote Flashing,Tested & Makemkv Discount Code
I currently have a LG HL-DT-ST BD-RE WH16NS60 that I flashed years ago that can read some UHD drives, but not others. Will I have better luck with these Pioneer drives?
Likely yes pioneers are much more reliable and consistent
DennisOlof
Will there be any exception for shipping outside USA now that you are selling the last batch of Pioneer drives ?
NoDennisOlof wrote: ↑Sat Jan 17, 2026 8:07 pmWill there be any exception for shipping outside USA now that you are selling the last batch of Pioneer drives ?
Just got my Billycar Pioneer BDR-XD08G setup and ready to go with Libredrive right out of the box.
No setup required. Plugged in and MakeMKV detected it perfectly. Just finished ripping the first disc with it.
Thank You!
Thank You!
Thank you!Billycar11 wrote: ↑Tue Jan 13, 2026 11:05 pmLikely yes pioneers are much more reliable and consistent
Just wanted to drop in and say thank you again to Billy. Bought another Pioneer this time it was the BDR-X08U in gold and it works flawlessly. Just plug and play.
Recently snagged a Verbatim 43890 that luckily had a pioneer drive in it, and also purchased a flashed Pioneer BDR-XD08B from Billycar11. The flasher setup he sent for the Verbatim worked without issue and the BDR-XD08 worked like a charm right out of the box!
Had one UHD Blu-ray that wouldn't detect with the 43890, but the BDR-XD08 recognized it first try. Glad I had a backup drive.
Thank you for your services Billycar11!
