[Solved] Questions on Pioneer BDR-UD04D
kyw504100
Post by kyw504100 »
Hi everyone,
I am new to makemkv and I just purchased a Pioneer BDR-UD04D from AliExpress.
The drive should be able to read UHD discs and LibreDrive ready as I seen other's drive work as well, and the drive is listed on the SDF.bin
But when I open makemkv, no LibreDrive information is shown.
The drive is connected to the PC via a USB3.0 enclosure, and can rip normal Blu-ray and DVD discs normally but unfortunately I currently don't have any UHD discs on hand to test.
Am I doing something wrong or I need to patch the drive?
Re: Questions on Pioneer BDR-UD04D
The D at the end is sus
Likly a fake unless case is just messing up libre drive info
Try direct data or one of the approved adapters in the guide
kyw504100
Post by kyw504100 »
Billycar11 wrote: Fri Jan 23, 2026 1:29 pm The D at the end is sus
Thanks for the suggestion.
A quick update here,
I ordered a SATA 15pin to 7pin power cable and connect the drive directly to the PC,
and everything seems normal now.
So your speculation is correct, the case is messing up the drive info.
Anyway, is the drive ready to rip UHD discs?
Thanks again!
kyw504100 wrote: Tue Jan 27, 2026 8:47 am
Thanks again!
Should
OnionBeard
Re: [Solved] Questions on Pioneer BDR-UD04D
Post by OnionBeard »
Can you send a link where you got them from on aliexpress?
Someone in my area has UD04s listed but they only show makemkv screengrabs and a pic of the side of a few boxes. The packaging says usb 3.0 and i’m pretty sure they are supposed sata. Either would try to order from the same link or compare packaging if possible
