Input File Not found and Unable to load sdf.bin
habib_15
#1 Post by habib_15 » Thu Jan 22, 2026 11:21 pm
I'm trying to update the firmware on my drive, and the commands are not working for me. I am using MakeMKV 1.18.2 from Ubuntu 24.04 snap.
Here is my problem:
$ sudo makemkvcon f -l
Found 1 drives(s)
00: dev_21:0, /dev/sr0, /dev/sr0
  HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_KLZK8HF3900
 $ sudo makemkvcon f -d 'dev_21:0' -f ./sdf.bin rawflash main -i ./DE_LG_WH16NS40-NS50_1.02.bin
Input file not found -- ./DE_LG_WH16NS40-NS50_1.02.bin
Internal error 0x83000001
I also get this error when just trying to dump the current firmware
sudo makemkvcon f -f ./sdf.bin --drive=dev_21:0 dump
Internal error 0xffffffff
Both sdf.bin and the firmware file are there and I had the console autocomplete the file names so I know it was spelled correctly. I feel like this is some sort of permission error with snaps, but it looks like the snap has access to my home folder where these files are found.
Any ideas?
flojo
Re: Input File Not found and Unable to load sdf.bin
#2 Post by flojo » Fri Jan 23, 2026 12:36 pm
Yeh, it looks like makemkvcon's $PWD is not what you think it is.
habib_15
#3 Post by habib_15 » Fri Jan 23, 2026 2:35 pm
It does the same error if I use the full path too.
habib_15
#4 Post by habib_15 » Fri Jan 23, 2026 4:40 pm
Ok, for anyone finding this post this is what I had to do.
  1. Uninstall the snap, that version of MakeMKV does not work to flash new firmware on the drive.
  2. Download and compile Version 1.17.7 found here at https://makemkv.com/download/old/ (Google how to build MakeMKV for the build instructions)
  3. Use DE_LG_WH16NS60_1.02_MK.bin not DE_LG_WH16NS40-NS50_1.02.bin
  4. Type: makemkvcon f -d /dev/sr0 -f ./sdf.bin rawflash enc -i ./DE_LG_WH16NS60_1.02_MK.bin
That executed correctly for me and shows the Drive firmware is now at 1.02 in MakeMKV's drive info panel.
flojo
#5 Post by flojo » Fri Jan 23, 2026 6:22 pm
I thought a snap had it's root at $HOME/snap/app name/..something / something
Obviously I don't use snap, but it's not surprising that a host path doesn't work as a jailed path.
