New computer,trouble activating software
ccbaz
do i have to buy another code? the one i've got isnt working on my new PC. Has anyone else run into this?
Re: New computer,trouble activating software
Enter the code you previously received. One code works for all computers you own.
ccbaz
I tried this. it says "invalid" and the "okay"button is grayed out
ccbaz
turns out i mixed up "1" and "l" in the code. I apologise for wasting forum resources and user time, thanks
Yes, letters and numbers can screw things up. And let's not go into the copy/paste from certain mail programs into other programs inserting <cr> or <lf> (or both) when you don't use the correct paste command (I remember when you didn't have to use the <shift> key to say "yes, just what I copied!") to the computer.
