Public KeyDB Disc Submissions
knolle123
#1636 Post by knolle123 » Thu Jan 22, 2026 4:08 pm
Disc type: UHD
Disc ID: 863AA9F0B6356D4F4BEEF09901CC606CB49DA26D
Disc dump filename: MKB20_v82_ONE_BATTLE_AFTER_ANOTHER_DD6C
Drive: ASUS_BW-16D1HT_3.10
Drive firmware: 3.10
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/0rdsCU8VgBKY
Disc dump link: https://transfer.it/t/N7oreF1B3ZYR
kasko
#1637 Post by kasko » Thu Jan 22, 2026 4:51 pm
MrPenguin wrote: Thu Jan 22, 2026 11:04 am
I think the KEYDB entry for this disk is correct.
I restarted it now and it's working, I have no idea why it didn't work this morning.
Thank you
SMD88
#1638 Post by SMD88 » Thu Jan 22, 2026 5:33 pm
Coopervid wrote: Thu Jan 22, 2026 10:32 am
SMD88 wrote: Thu Jan 22, 2026 10:29 am
keydb_helper wrote: Thu Jan 22, 2026 9:43 am
It is hard to speculate on what might be the issue without any information about the error message or error code. Are you receiving a decryption error? Or is it a read error? If it is a read error, I can't suggest anything other than cleaning the disc and trying a different disc drive.
Very true, I am sorry about that! I am not home at the moment but I will add the information when I can.
When I open the disc, it takes a good few minutes to go through the "dycrypting" stage, and then fails. It gives two debug codes and says the disc cannot be decrypted. Much like posts I have seen where the keydb file was not being read by Makemkv.
Wash the disc wit liquid soap and warm water. Dry witha microfiber cloth. If you get still an error post it here .
I did run the disc through the hash check and it verified 100%. So I don't think it is a dirty disc problem. Arrow UK's discs are usually perfect, but I will try it. Thank you.
frameloose
#1639 Post by frameloose » Thu Jan 22, 2026 6:07 pm
MKB20_v82_One_Battle_After_Another_1CA2
SamSpeexy
#1640 Post by SamSpeexy » Thu Jan 22, 2026 9:10 pm
SMD88 wrote: Thu Jan 22, 2026 9:15 am I have been trying in vein to rip Arrow's City On Fire. Has anyone managed to rip it?
I have used Keydb Helper to get the keys, but it still refuses to work. I used the programme previously to rip Little Darlings and it was quick and easy. This damned Arrow disc refuses to work for me. Very frustrating. I am not sure what I am doing wrong.
According to this thread, the UHD is not encrypted.
viewtopic.php?f=12&t=40089
keydb_helper
#1641 Post by keydb_helper » Fri Jan 23, 2026 3:18 am
zaphod42 wrote: Thu Jan 22, 2026 11:17 am Disc dump "MKB_v82_ONE_BATTLE_AFTER_ANOTHER_E390"
knolle123 wrote: Thu Jan 22, 2026 4:08 pm Disc dump filename: MKB20_v82_ONE_BATTLE_AFTER_ANOTHER_DD6C
frameloose wrote: Thu Jan 22, 2026 6:07 pm MKB20_v82_One_Battle_After_Another_1CA2
Thanks for the new disc submissions. One variant after another has been added to the public keydb.
SamSpeexy wrote: Thu Jan 22, 2026 9:10 pm According to this thread, the UHD is not encrypted.
Thanks for the reminder SamSpeexy. I forgot that City on Fire had previously been discussed within this thread: Link.
KeyDB Download
#1642 Post by SamuriHL » Fri Jan 23, 2026 3:22 am
KeyDB Helper should have caught that and displayed a message about it. Granted, it's an experimental feature I added but in theory it should have been able to check.
zaphod42
#1643 Post by zaphod42 » Fri Jan 23, 2026 7:28 am
keydb_helper wrote: Fri Jan 23, 2026 3:18 am
Great! It works... Thanks a lot :-)
mich52
#1644 Post by mich52 » Fri Jan 23, 2026 4:42 pm
Disc type: UHD
Disc ID: 3b246daf52261b5e2d15616661fb48e369cd89e4
Disc dump filename: MKB20_v82_BEASTMASTER_6B50
Drive: WH16NS60
Drive firmware: 1.02
MKB_RO.inf link: https://transfer.it/t/h9Tvb04BBT7J
Disc dump link: https://transfer.it/t/IMaQK9pF1TpR
Thank you!
daofail
#1645 Post by daofail » Fri Jan 23, 2026 7:34 pm
Disc type: UHD
Disc ID: 0xAB9BDC07D7FEC17BA080D25C8AC3E210466474E2
Disc dump filename: MKB20_v61_MARVEL'S_GUARDIANS_OF_THE_GALAXY_VOL_2_320D.tgz
Drive: BD-RE BP60NB10
Drive firmware: 1.02 / Patched
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/JPTEy5pFyR6K
Disc dump link: https://transfer.it/t/JPTEy5pFyR6K
daofail
#1646 Post by daofail » Sat Jan 24, 2026 3:42 am
Disc type: UHD
Disc ID: 0xCE0E92490D1BEC137677525BB9F52BBD334E8CF5
Disc dump filename: MKB20_v65_MARVEL'S_ANT-MAN_AND_THE_WASP_-_ULTRA_HD_6B37.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/4IL7WwxVELxb
Disc dump link: https://transfer.it/t/4IL7WwxVELxb
daofail
#1647 Post by daofail » Sat Jan 24, 2026 3:50 am
Disc type: UHD
Disc ID: 0x4BDB7D4537206BC63AE4EA743A316B8BA7C0CCC0
Disc dump filename: MKB20_v68_MARVEL'S_AVENGERS-_INFINITY_WAR_0929.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/d22sy8wFzBAL
Disc dump link: https://transfer.it/t/d22sy8wFzBAL
Thank you!
daofail
#1648 Post by daofail » Sat Jan 24, 2026 3:58 am
Disc type: UHD
Disc ID: 0xF5F639A07D53FABD44B6AF71BECFF935555AB069
Disc dump filename: MKB20_v61_MARVEL'S_BLACK_PANTHER_A5CB.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/Qp1be4hxgZDR
Disc dump link: https://transfer.it/t/Qp1be4hxgZDR
Thank you!
daofail
#1649 Post by daofail » Sat Jan 24, 2026 4:04 am
Disc type: UHD
Disc ID: 0xEAE8BD80F721EE92FA5C64C7D37915810E496645
Disc dump filename: MKB20_v61_MARVEL'S_THOR-_RAGNAROK_8E7B.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://transfer.it/t/Xvx4D1gjCJ5Z
Disc dump link: https://transfer.it/t/Xvx4D1gjCJ5Z
Thank you!
vonMalm
#1650 Post by vonMalm » Sat Jan 24, 2026 6:03 am
Disc type: Blu-ray
Disc ID: 0x1A9B84BEB8E3BA8DCFBE007D3840407F1C6E454E
Disc dump filename: MKB_v82_ONE_BATTLE_AFTER_ANOTHER_F9A6.tgz
Drive: ASUS BW-16D1HT
LibreDrive status: Active
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/open?id=1gPZFa ... p=drive_fs (tested)
Disc dump link: https://drive.google.com/open?id=1LGQkp ... p=drive_fs (tested)
My first one, hope all is in order...
