Pioneer BDR-UD03 UHD possibility
BDR_UD03
Re: Pioneer BDR-UD03 UHD possibility
Post by BDR_UD03 »
blind-s33r wrote:
Mon Jan 19, 2026 12:11 am
zaqqaz6917 wrote:
Sun Jan 18, 2026 10:44 pm
    It seems currently Office depot usa is a good source for pioneer/verbatim ud-03 with pre 2023 terror firmware
    Also offering a 25% sign up code.
    They were, I managed to grab a few but now their website says out of stock and everywhere around I check for pickup is also oos... but It was a nice last ditch find for some pioneers.
    Was lucky to get one too from my local store, they seemed to have others in stock but at the checkout they said mine was the last one. Was tempted to grab another one online.
    adam871
    Post by adam871 »
    Hi, I have a problem with Pioneer BDR-UD03 - try to read a UHD disc and it doesn't work.
    Optical Drive Properties
    Device Description PIONEER BD-RW BDR-UD03 USB Device
    Serial Number
    Firmware Revision 1.05
    Firmware Date 24.11.2015
    Buffer Size 4000 KB
    Region Code None
    Remaining User Changes 5
    Remaining Vendor Changes 4
    adam871 wrote:
    Thu Jan 22, 2026 2:54 pm
    Serial Number
    Buffer Size 4000 KB
    Region Code None
    Post your makemkv info and most likely you will be able to flash the drive.
    adam871
    Post by adam871 »
    Coopervid wrote:
    Thu Jan 22, 2026 3:08 pm
    Serial Number
    Buffer Size 4000 KB
    Region Code None
    How do I do this? Should I buy this program? I never have the firmware version 1.14.
    OS device name: F:
    Manufacturer: PIONEER
    Product: BD-RW BDR-UD03
    Revision: 1.05
    Serial number:
    Firmware date: 2015-11-24
    Drive platform: RS8510
    Firmware version: 1.05
    adam871 wrote:
    Thu Jan 22, 2026 3:26 pm
    Serial Number
    Buffer Size 4000 KB
    Region Code None
    OS device name: F:
    Revision: 1.05
    Serial number:
    You have a PM now.
    Riff Raff
    Post by Riff Raff »
    Hey sry for pushing my post up but there are several posts already answered which where postet long after me.
    I guess my post was overlooked somehow? :)
    Riff Raff wrote:
    Wed Dec 24, 2025 8:57 am
    Got one of these as well. :D
    OS-Gerätename: E:
    Produzent: PIONEER
    Produkt: BD-RW BDR-UD03
    Revision: 1.11
    Serienummer: TGDL328735WL
    Firmware-Datum: 2018-11-28
    Drive platform: RS8511
    Firmware version: 1.11
      BDR_UD03
      Post by BDR_UD03 »
      Coopervid wrote:
      Thu Jan 22, 2026 4:14 pm
      You have a PM now.
      Hi Coopervid, could you check this one:
      Revision: 1.14
      Serial number:
      Firmware date: 2020-06-15
      Highest AACS version: 68
      Firmware version: 1.14
      Riff Raff wrote:
      Fri Jan 23, 2026 9:08 pm
      OS-Gerätename: E:
      Produzent: PIONEER
      Revision: 1.11
        PM sent. Yes, your post was missed somehow.
        milkdudd32
        Post by milkdudd32 »
        I also got the Verbatim drive from Office Depot. Can I also get some assistance with it being flashed? Much appreciated.
        OS device name: F:
        Revision: 1.14
        Serial number:
        milkdudd32 wrote:
        Sun Jan 25, 2026 5:16 am
        OS device name: F:
        Revision: 1.14
        Serial number:
        PM sent.
        DRAGON26
        Post by DRAGON26 »
        OS device name: F:
        Revision: 1.14
        Serial number: AFDL409054WL
        DRAGON26 wrote:
        Wed Jan 28, 2026 9:21 am
        OS device name: F:
        Revision: 1.14
        PM sent.
        blu3r1d3r
        Post by blu3r1d3r »
        I would like to be able to read UHD discs. Thanks.
        OS device name: /dev/sr0
        Revision: 1.14
        Serial number: BHDL500276WL
        tsangkaiming
        Post by tsangkaiming »
        same problem on UHD. Would you please help if possible
        blu3r1d3r wrote:
        Fri Jan 30, 2026 5:08 pm
        Revision: 1.14
        PM sent.
