Pioneer BDR-UD03 UHD possibility
BDR_UD03
Re: Pioneer BDR-UD03 UHD possibility
#1051 Post by BDR_UD03 » Wed Jan 21, 2026 4:47 am
blind-s33r wrote:
Mon Jan 19, 2026 12:11 am
zaqqaz6917 wrote:
Sun Jan 18, 2026 10:44 pm
    It seems currently Office depot usa is a good source for pioneer/verbatim ud-03 with pre 2023 terror firmware
    Also offering a 25% sign up code.
    They were, I managed to grab a few but now their website says out of stock and everywhere around I check for pickup is also oos... but It was a nice last ditch find for some pioneers.
    Was lucky to get one too from my local store, they seemed to have others in stock but at the checkout they said mine was the last one. Was tempted to grab another one online.
    adam871
    #1052 Post by adam871 » Thu Jan 22, 2026 2:54 pm
    Hi, I have a problem with Pioneer BDR-UD03 - try to read a UHD disc and it doesn't work.
    Optical Drive Properties
    Device Description PIONEER BD-RW BDR-UD03 USB Device
    Serial Number
    Firmware Revision 1.05
    Firmware Date 24.11.2015
    Buffer Size 4000 KB
    Region Code None
    Remaining User Changes 5
    Remaining Vendor Changes 4
    #1053 Post by Coopervid » Thu Jan 22, 2026 3:08 pm
    Serial Number
    Buffer Size 4000 KB
    Region Code None
    Post your makemkv info and most likely you will be able to flash the drive.
    adam871
    #1054 Post by adam871 » Thu Jan 22, 2026 3:26 pm
    Serial Number
    Buffer Size 4000 KB
    Region Code None
    How do I do this? Should I buy this program? I never have the firmware version 1.14.
    OS device name: F:
    Manufacturer: PIONEER
    Product: BD-RW BDR-UD03
    Revision: 1.05
    Serial number:
    Firmware date: 2015-11-24
    Drive platform: RS8510
    Firmware version: 1.05
    #1055 Post by Coopervid » Thu Jan 22, 2026 4:14 pm
    Serial Number
    Buffer Size 4000 KB
    Region Code None
    OS device name: F:
    Revision: 1.05
    Serial number:
    You have a PM now.
    Riff Raff
    #1056 Post by Riff Raff » Fri Jan 23, 2026 9:08 pm
    Hey sry for pushing my post up but there are several posts already answered which where postet long after me.
    I guess my post was overlooked somehow? :)
    Riff Raff wrote:
    Wed Dec 24, 2025 8:57 am
    Got one of these as well. :D
    OS-Gerätename: E:
    Produzent: PIONEER
    Produkt: BD-RW BDR-UD03
    Revision: 1.11
    Serienummer: TGDL328735WL
    Firmware-Datum: 2018-11-28
    Drive platform: RS8511
    Firmware version: 1.11
      BDR_UD03
      #1057 Post by BDR_UD03 » Sat Jan 24, 2026 10:07 am
      You have a PM now.
      Hi Coopervid, could you check this one:
      Revision: 1.14
      Serial number:
      Firmware date: 2020-06-15
      Highest AACS version: 68
      Firmware version: 1.14
      #1058 Post by Coopervid » Sat Jan 24, 2026 10:37 am
      OS-Gerätename: E:
      Produzent: PIONEER
      Revision: 1.11
        PM sent. Yes, your post was missed somehow.
        milkdudd32
        #1059 Post by milkdudd32 » Sun Jan 25, 2026 5:16 am
        I also got the Verbatim drive from Office Depot. Can I also get some assistance with it being flashed? Much appreciated.
        OS device name: F:
        Revision: 1.14
        Serial number:
        #1060 Post by Coopervid » Sun Jan 25, 2026 2:57 pm
        OS device name: F:
        Revision: 1.14
        Serial number:
        PM sent.
        DRAGON26
        #1061 Post by DRAGON26 » Wed Jan 28, 2026 9:21 am
        OS device name: F:
        Revision: 1.14
        Serial number: AFDL409054WL
        #1062 Post by Coopervid » Thu Jan 29, 2026 10:59 am
        OS device name: F:
        Revision: 1.14
        PM sent.
        blu3r1d3r
        #1063 Post by blu3r1d3r » Fri Jan 30, 2026 5:08 pm
        I would like to be able to read UHD discs. Thanks.
        OS device name: /dev/sr0
        Revision: 1.14
        Serial number: BHDL500276WL
        tsangkaiming
        #1064 Post by tsangkaiming » Sat Jan 31, 2026 2:54 am
        same problem on UHD. Would you please help if possible
        #1065 Post by Coopervid » Sat Jan 31, 2026 9:29 am
        Revision: 1.14
        PM sent.
