Hi, in reference to
http://www.makemkv.com/forum2/viewtopic.php?f=1&t=4702
Is there a command line option I can use since I can not use the ui with no accessability. The way I am doing it now is to have my gf insert dvd or bd start makemkv, click on the drive then click on save mkv. If there was a command line option I could use then I could at least put the movie in the mkv container myself for her and others to watch in the house until hopefully the accessability will be turned on.
The file lands in my c:\vidieos\movie name folder.
I'm hoping this is keeping the best quality mkv as I just installed the ap, entered the serial number and then used the two click method, makemkv seems to select everything (all title) by default.
is there a command line option
Re: is there a command line option
I haven't able to try it yet, but I am sure that once your MKV file has been saved, you shouldn't have to worry about it.
Thanks, what about command line options so I then could rip the dvd/bd myself?
- Contact:
