Hi. My name is Toni and I'm from Germany. I'm writing here with a translator and hope that you understand what I want to say.
I started collecting movies (4K UHD and Blu-Ray) not too long ago. Now I want to back them up or rip them. I'm going to use a Macbook Air M4 for this.
I don't think I have any major requirements.
- Internal or external drive (if external, a case would be nice)
- USB-C connection would be nice
The only thing that's really important to me is that the drive works well and isn't too expensive. Although the last point is pretty unlikely, as it seems that drives are hard to find now.
I have tried to read up on this and collect some information.
It seems that 4K UHD-compatible drives are no longer being produced and are therefore becoming rare. A distinction must be made between drives that first need to be flashed with special firmware. This probably has to be done via Windows. If I have read correctly, a VM via macOS is not sufficient for this? That would eliminate that option for me, as I don't have a Windows device.
There are also certain drives that are already suitable for ripping ex works, provided they have the right firmware.
There are also retailers that sell pre-configured drives. I have already identified ASMCOM as a retailer for Europe. As soon as they are back in stock, I will send them an inquiry.
I quickly found the following drives. It would be great if someone could tell me whether these can be used without flashing.
First, there is the Verbatim 43888. I guess I have to make sure that it has a Pioneer drive installed? But you can only find that out by reading it with MakeMKV, right?
https://www.idealo.de/preisvergleich/Of ... batim.html
Another drive I found is this one:
https://www.amazon.de/techPulse120-Supe ... WQPGJ&th=1
Is anyone of these devices any good, or would you recommend another one?
Sorry for the long text. I hope you can help me.
Have a nice day.
Greetings from Germany
Newbie needs help finding a 4K UHD drive
Re: Newbie needs help finding a 4K UHD drive
The Verbatim 43888 only has a LG BU40N inside but can easily be flashed. They have not had Pioneer drives in them since March 2025. A good VM such as VMware among others can be used on Mac with Windows 11 64 bit and SDFtool flasher or you can just use the CLI on Mac to flash the 43888.PapaBaer wrote: Wed Jan 21, 2026 8:41 am Hi. My name is Toni and I'm from Germany. I'm writing here with a translator and hope that you understand what I want to say.
Have a nice day.
No, the Techpulse is not a recommended drive.
Some other Verbatim models such as 43887 and 43890 may still contain a Pioneer drive inside if you are lucky.
Hubldidubldi
Hi, I am also new here and was wondering if there is any significant difference between the different verbatim drives other than the potential LG vs Pioneer. If they all come with an LG, does it matter which one I get? If not, would 43890 be best if price is equal because there is still a chance it comes with a Pioneer?MartyMcNuts wrote: Thu Jan 22, 2026 12:12 amThe Verbatim 43888 only has a LG BU40N inside but can easily be flashed. They have not had Pioneer drives in them since March 2025. A good VM such as VMware among others can be used on Mac with Windows 11 64 bit and SDFtool flasher or you can just use the CLI on Mac to flash the 43888.PapaBaer wrote: Wed Jan 21, 2026 8:41 am Hi. My name is Toni and I'm from Germany. I'm writing here with a translator and hope that you understand what I want to say.
Have a nice day.
Thanks for the help!
If it's a LG, it will be a BU40N, regardless of the model, so no, it doesn't really matter which one you get. If you are hoping for a Pioneer, yeah go for the 43887 or 43890.Hubldidubldi wrote: Mon Feb 09, 2026 12:09 pmHi, I am also new here and was wondering if there is any significant difference between the different verbatim drives other than the potential LG vs Pioneer. If they all come with an LG, does it matter which one I get? If not, would 43890 be best if price is equal because there is still a chance it comes with a Pioneer?MartyMcNuts wrote: Thu Jan 22, 2026 12:12 amThe Verbatim 43888 only has a LG BU40N inside but can easily be flashed. They have not had Pioneer drives in them since March 2025. A good VM such as VMware among others can be used on Mac with Windows 11 64 bit and SDFtool flasher or you can just use the CLI on Mac to flash the 43888.PapaBaer wrote: Wed Jan 21, 2026 8:41 am Hi. My name is Toni and I'm from Germany. I'm writing here with a translator and hope that you understand what I want to say.
Have a nice day.
science-nerd
I got a few of the Verbatim 43888 and can give you info or hook you up with a pre-flashed drive if you don't want to risk it.
Also from Germany
Also from Germany
