Re: SDFtool Flasher
Post by MartyMcNuts » Wed Jan 21, 2026 10:12 pm
the_pharaohs_cat wrote: Wed Jan 21, 2026 10:21 am Hiya,
I've been having trouble trying to use SDFtool Flasher. Sorry if I miss out relevant details, I'm new to all this stuff.
Below is my drive information from MakeMKV:
Product: BD-RE BU40N
Revision: 1.05
Serial number: MO5P5MF1048
Highest AACS version: 61
I was attempting to use the SDFtool Flasher today, but I kept encountering the following error message:
Input string was not in a correct format.
When I expanded it to see the details, this was the message:
System.FormatException: Input string was not in a correct format.
at System.Number.ThrowOverflowOrFormatException(ParsingStatus status, TypeCode type)
at System.Convert.ToInt32(String value)
at SDFtool_Flasher_Updated.Form1.<>c__DisplayClass46_0.<<button_START_Click>b__2>d.MoveNext()
--- End of stack trace from previous location ---
at System.Threading.Tasks.Task.<>c.<ThrowAsync>b__128_0(Object state)
I'm not sure if I'm flashing the correct file. I've tried LG_BU40N_1.03_MK and LG_BU40N_1.00.
Sorry if these are obviously the wrong files, as I said above, I'm rather new to all of this. Any help would be appreciated.
Thanks.
Ensure MakeMKV is installed in the default location (C:\Program Files (x86)).
Ensure there is no disc in the drive and the tray is closed.
I assume this is a Verbatim 43888, 43889 or 43890? As v1.05 is encrypted, you must use BU40N_1.03_MK first. Once flashed, you can leave it or then flash to BU40N_1.00.
Szary Kot
Re: SDFtool Flasher
Post by Szary Kot » Thu Jan 22, 2026 8:23 am
I'd like to ask the experts on the subject which is better to buy: BW-16D1HT BOX or Verbatim 43888?
Which lasts longer?, Does the sleep error also affect the Verbatim 43888?
Licensed User MakeMKV
Re: SDFtool Flasher
Post by MartyMcNuts » Thu Jan 22, 2026 9:45 am
Szary Kot wrote: Thu Jan 22, 2026 8:23 am I'd like to ask the experts on the subject which is better to buy: BW-16D1HT BOX or Verbatim 43888?
1. 43888
2. Impossible to predict. Every drive is different.
3. No.
Noob123
Re: SDFtool Flasher
Post by Noob123 » Fri Jan 23, 2026 8:02 pm
I have a follow up question.
Does it matter which firmware version I have installed in terms of being able to read the most amount of UHD and Blue Ray discs? I have been having been experiencing a lot of back up failures recently and am wondering if it is related? I read that someone had installed Firmware version 1.03 and that had resolved some disc readability issues they had been having. Should I stick with firmware version 1.00?
Noob123 wrote: Mon Jan 05, 2026 10:31 pm I'm new to the forum and this is my first post.
I recently purchased a Verbatim 6888 optical drive and attempted to use the SDFtool Flasher to flash the firmware. The internal drive is the BU40N model. I have attempted to back up several of my UHD discs but they have all failed. Can anyone check my drive information to verify that I have successfully enabled LibreDrive?
OS device name: /dev/rdisk7
Revision: 1.00
Serial number: -
Firmware date: 2116-12-20 15:28
Highest AACS version: 81
Firmware version: 1.00
nicholfd
Re: SDFtool Flasher
Post by nicholfd » Fri Jan 23, 2026 8:20 pm
Noob123 wrote: Fri Jan 23, 2026 8:02 pm I have a follow up question.
Revision: 1.00
Serial number: -
Probably not related to the firmware.
For 4K/UHD - check the power to the USB drive. Be sure you have a good external power supply or are using 2 x USB connections to USB ports that supply enough power.
Thanks,
Frank
bemml
Re: SDFtool Flasher
Post by bemml » Mon Jan 26, 2026 6:49 am
sorry to bother you, but the mediafire links are not working anymore.
Re: SDFtool Flasher
Post by MartyMcNuts » Tue Jan 27, 2026 12:55 am
bemml wrote: Mon Jan 26, 2026 6:49 am sorry to bother you, but the mediafire links are not working anymore.
Yes, they are. Just checked and are working fine.
Szary Kot
Re: SDFtool Flasher
Post by Szary Kot » Wed Jan 28, 2026 5:38 pm
Hi Marty,
What's the difference between the BU40N_1.03_MK firmware and the BU40N_1.00 firmware?
I'm asking from a user perspective.
Does one support BDXL discs better than the other?
I'm mainly concerned about writing discs.
I know that version 1.00 is compatible with other programs, not just MakeMKV.
the_pharaohs_cat
Re: SDFtool Flasher
Post by the_pharaohs_cat » Wed Jan 28, 2026 8:53 pm
MartyMcNuts wrote: Wed Jan 21, 2026 10:12 pm Ensure MakeMKV is installed in the default location (C:\Program Files (x86)).
Sorry for the late reply, I've been really busy all week. Thanks so much for the help, I tried flashing it again last night and it worked.
Re: SDFtool Flasher
Post by MartyMcNuts » Wed Jan 28, 2026 11:46 pm
Szary Kot wrote: Wed Jan 28, 2026 5:38 pm Hi Marty,
For UHD discs, MK firmware is only compatible with MakeMKV and Xreveal. 99% of people here don't care about writing discs.
gock01
Re: SDFtool Flasher
Post by gock01 » Sat Jan 31, 2026 3:58 pm
I have a Verbatim 43888 DVD player, model number: BD-RE BU40N
Revision: 1.05
I haven't flashed it yet, but if I flash it one day and later want to revert to the original firmware as it was when I bought it, how can I do that?
I haven't been able to find the original firmware file on the Verbatim website.
Thank you for your help.
Data from Make MKV before flashing
OS device name: F:
Revision: 1.05
Serial number: *****
Highest AACS version: 76
Re: SDFtool Flasher
Post by MartyMcNuts » Sat Jan 31, 2026 10:16 pm
gock01 wrote: Sat Jan 31, 2026 3:58 pm Hello,
Revision: 1.05
OS device name: F:
Revision: 1.05
The drive is a LG BU40N. You can get the original LG flasher from LG's website.
meepster
Re: SDFtool Flasher
Post by meepster » Fri Feb 06, 2026 9:12 pm
i have a ASUS usb drive was wonderring what do i need to flash with to make is Usable.
i have the flasher and all the firmwares just wondering what one or ones i need to use the drive is encrypted.
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Highest AACS version: 70
Re: SDFtool Flasher
Post by MartyMcNuts » Fri Feb 06, 2026 11:21 pm
meepster wrote: Fri Feb 06, 2026 9:12 pm i have a ASUS usb drive was wonderring what do i need to flash with to make is Usable.
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
If you still write/burn discs, use BW-16D1HT 3.10-MK. If you only rip discs and don't care about writing/burning discs, use WH16NS60 1.02-MK.
kaysee
Re: SDFtool Flasher
Post by kaysee » Sat Feb 07, 2026 1:39 am
But what if you want to copy discs but not with jamless playback introducing fake data in error regions?
